Old 07-05-2003, 12:40 AM   #1
My stock van = 12lbs of boost?
My Ride: 89 Caravan
Is this normal? My van is bone stock, right down to the paper air filter and it will hold a steady 12 lbs of boost. Before I fixed the timing that was off a tooth or two it would only go to 8. Now 12?
Thanks,
Jeff
My96z is offline
Old 07-05-2003, 12:00 PM   #2
cool!
89turbovan
thats what you got after fixing the timing! guess i really need to check mine, my van just has no balls and im trying to figure it out.
Old 07-05-2003, 12:48 PM   #3
That is what mine did stock with open exhaust. Before the exhaust it would go to 10lbs.
turbulence is offline
Old 07-05-2003, 04:25 PM   #4
My Ride: 89 Caravan
I thought it was a little bit high as I even have the stock exhaust. I wonder what it will be when I go to a 3" exhaust here soon?
89turbovan. Yea man, my cam timing was a tooth or two off, it had good low end but no top end at all. You should check it.
Thanks guys,
Jeff
My96z is offline
Old 07-05-2003, 10:50 PM   #5
89turbovan
checked it tonight not 100% sure its on think it might be off got to pull the valve cover off and line up the holes. Check the plug wires tonight also, ends in the cap are HAMMERED so is the rotor got to change them! Plus i found out the rod from the wastegate canister is rotted away not hook up on the flap. Lots to do yet!!
Old 07-05-2003, 10:54 PM   #6
My Ride: 89 Caravan
I didnt pull off the valve cover, I just used a mirror to check.
Your van sounds like mine...in need of some TLC.
Jeff
P.S read here to get the full skinny... good links that I used.
Confused... Van falls on its face at full throttle?
My96z is offline
Old 07-05-2003, 11:02 PM   #7
89turbovan
how did you use a mirror? I kept looking at it and could not say if it was off or not looks real close. The hep is already changed had to that a little while ago! I just want to get this thing runnig good!
Personal Finance | Free Ringtone | Myspace Layouts | Mobile Phone | Myspace Proxy
Page generated in 0.42434 seconds with 13 queries
