Old 07-05-2003, 10:57 PM   #1
wastegate
89turbovan
I cant move the wastegate rod(well whats left of it) thats bad right!? if it is, is it easy to get a new one?
Old 07-05-2003, 11:18 PM   #2
The rod is internally attached to the wastegate can, so you'll have to reaplace the can.
Yes, it's easy to get a new/used one.
lametec is offline
Old 07-05-2003, 11:31 PM   #3
89turbovan
thats what i ment to say the can. thanks for the info. is it easy to replace on car or do you got to pull the head off to get to it?
Old 07-06-2003, 01:41 AM   #4
Assuming you're talking about your van, it's easy.
Unbolt two bolts that hold it onto the compressor housing, remove clip that holds it to wastegate flapper (if not already rusted off).
A little tight, but perfectly doable without taking off anything but the intake hose and air box.
lametec is offline
Old 07-06-2003, 12:52 PM   #5
89turbovan
been trying to find one online but no luck! have you seen one?
Old 07-06-2003, 03:15 PM   #6
Try the parts wanted forum.
lametec is offline
MPAA | Mobile Phones | Credit Card Shop | Bankruptcy | Free Advertising
Page generated in 0.32859 seconds with 13 queries
