07-05-2003, 11:42 PM
question about the GN tbo348 and an 8v
i'll supply you with a little info first...
"the gn turbo is bigger than any t3 made. its closeist cousin would be the to4b s trim. but it is a turbo made just for gm and is not avalible in the aftermarket, you cant even get a compressor map for it. the limitations of that compressor is about 375-400 hp. in your setup that exhaust turbine is too big. make a hybrid, find a t3 turbo with a .48 or .63 a/r and remove the entire compressor section. install your gn compressor and you ll have a fast spooling monster. I did. "
"this buick turbo has a .63 hot side, and i have been told the exhaust wheel is equivilant to a stage 2 t3."
the motor will be a 2.5/555 combo, mild ported g-head with back-cut valves, tbi header, downpipe and a muffler for exhaust, etc.
what do ya think.
