Old 07-10-2003, 10:51 PM   #1
turbo removal!
89turbovan
Anybody know if you can remove a t1 mitsu turbo from a 89 carvan without removing the head?
Old 07-10-2003, 10:56 PM   #2
It's possible with the right tools, but probably a lot easier and faster to simply pull the head.
Gives you an excuse to change the headgasket and timing belt too.
lametec is offline
Old 07-10-2003, 11:48 PM   #3
yes very simple 20min job dont even have to unbolt the exhaust. just unbolt the clamp between the exhaust and intake housings on the turbo. then tap the turbocharger out of the exhaust housing and replace it with a new one. dont forget to disconnect the oil and coolent lines
artur_p is offline
Old 07-11-2003, 08:33 AM   #4
Heh, didn't even think about that. I should have, 'cause I actually did it once! That was on a log intake, though.
lametec is offline
Old 07-11-2003, 08:50 AM   #5
thats what i like about these turbochargers very easy to service. the CT26 turbo i'm using is set up the same way except its much bigger:big grin:
artur_p is offline
Old 07-11-2003, 12:54 PM   #6
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
Is this the same easy procedure on a 92 gtc t1?
crazymadbastard is offline
Old 07-11-2003, 03:09 PM   #7
yes as long as you still have the mitsu turbocharger.
artur_p is offline
Old 07-11-2003, 04:21 PM   #8
JT
Put the mini on a lift, there's enough room to get back in there and change it.
Old 07-11-2003, 04:57 PM   #9
89turbovan
Thats cool i didn't even think about taking it apart first before removal!"thumbs up . Of course pullin the head might need to be done o well, thanks guys!"thumbs up "thumbs up
Mobile Phones | Song Lyrics | Credit Cards | Actress | Pacotes Carnaval Salvador
Page generated in 0.40370 seconds with 13 queries
