Old 10-27-2009, 04:14 PM   #1
Cool distinguish turbo ll or lll
My Ride: 91 gtc lebaron 2.5
Engine: 2.5 inter. t2
well i have a 91 gtc lebaron its not the stock setup. the owner said it is a t3 turbo. how can i tell a t2 turbo and head from a t3?
9125lebaron is offline
Old 10-27-2009, 04:21 PM   #2
Re: distinguish turbo ll or lll
My Ride: 85 chyslerlaserturbo
dose it have 2 cams or just 1 the t1 and t2 were 8v engines thus 1 camshaft. the t3s were 16v and had a twin cam head. If it has a 16v lotus head that would be cool but if it is a t3 it may have a 2.4 neon head on it.
spudwiser67 is offline
Old 10-27-2009, 04:32 PM   #3
yea it is a sohc but could my garret turbo be a t3? if so how can i tell?
Old 10-27-2009, 04:43 PM   #4
it could have a t3 turbo but not likly being a 8v . you will need to get the #s of the turbo for a good id. your the guy with the smoking turbo right if you need to replace it I would just pop the head off and pull the turbo if it has the exhaust manny redilled or has a standered t3 flang then it may be a t3 turbo.imo if you need to replace it i would go with a s60 not super cheap but they make power like crazzy.
Old 10-27-2009, 04:56 PM   #5
i already have them off what # do u need off the turbo to distinguish the size? or flange ? how can i distinguish a t1 head from t2?
Old 10-27-2009, 05:04 PM   #6
the heads are the same. with the turbo off look at the flang where the turbo bolts on the exhaust if the holes are all evenly spaced and driecly acrost from each other then it is a t3 but more than likely one of them will be offset i.e. it will not be a square pattern then it is a t1 or t2 . the 2.5 were all t1s unless some one spent a bit of money on this thing It is most likely still the stock turbo. the stocker on that car may be a mistu turbo. If it has been upgraded to a garrett t2 turbo that may be you confusion.
Old 10-27-2009, 05:12 PM   #7
Question Re: distinguish turbo ll or lll
yea ur right it is a t2 turbo, and if i hit over boost and i had some oil and and smoke coming out of it. could it be the turbo seal or worse? how could i distinguish the problem?
Old 10-27-2009, 05:48 PM   #8
Going Hybrid All Around
1983Rampage's Avatar
My Ride: 1989 Daytona ES
Engine: 2.5l T2
Feedback: (13)
Actually, the Garrett turbo that is used stock on the TD's is a T3 Garrett Turbo with a Chrysler flange. It is the same main cartridge as the Grand National and the Ford Turbo Coupe's. The difference between them is the A/R sizes of the turbine and compressor housings/wheels. If you have a stock looking turbo on the car, and it is a garrett, then it would be a T3 TURBO (not engine). And it probably came off of a normal T2 engine.
The best way to check a turbo is to remove the intake line going to the filter and see how much play the compressor wheel has in it. If you can really move the wheel, then it needs to be replaced. If you can move it maybe a millimeter left and right, and can't move it in and out, then I would say it is good to run. If the turbo needs replaced, you can get a rebuild for it, which all you would need is a T3 rebuild kit, and you can get them just about anywhere.
Which would you rather have, go fast goodies or shiny shoes?
Your feet may look good, but if your engine blows up, you ain't going anywhere.
1989 Dodge Daytona ES - T-top - 2.5l T2 with A555
1983 Dodge Rampage - 2.2l T2 with A525 (RIP)
1984 Dodge Rampage - 2.2l Carb with A525 (RIP)
1987 Dodge Shelby Charger GLHS #782 (RIP)
1987 Dodge Lancer ES - 2.2l T1 with A413 (RIP)
1983Rampage is offline
Old 10-27-2009, 06:28 PM   #9
The Red Baron
Polygon's Avatar
My Ride: 1989 LeBaron GTC
Engine: Turbo II 2.2L/135ci
Images: 79
Well, if it's a 91 then it didn't come with a T2 engine because that only came in the 89s and came with a 2.2L. Now, the T3 was never installed in a LeBaron but it was installed in the Mexican Phantom R/T version and would have also had a 2.2L.
Your car came stock with a 2.5L T1 with a Mitsubishi TE04H turbo.
Clint: 1989 LeBaron GTC Turbo II - 1991 Dodge Stealth R/T TT
My CarDomain Garage
Polygon is offline
Old 10-27-2009, 06:39 PM   #10
Feedback: (11)
Why not just post some pictures of the engine and turbo?
thinkofhairy is online now
Old 11-07-2009, 10:41 PM   #11
here ya go
Old 11-07-2009, 10:52 PM   #12
My Ride: 89 Daytona
Engine: 2.2 T2
Feedback: (8)
Images: 17
That is a Garrett T3 turbo, came on the T2 cars and the early log T1's had it too. It can cause some confusion lol.
jory is offline
Old 11-07-2009, 11:53 PM   #13
Feedback: (11)
To be more exact, that's a 87 TII turbo. Comes with 2 1/4 inch small flange swing valve and small actuator.
Page generated in 0.19794 seconds with 10 queries
