Old 07-17-2003, 08:12 PM   #1
test turbos
My Ride: 87 SL-85 GLHT-98 VOY
Engine: 2.2 turbo I
any one know how to check or test a turbo to see if it is any good before putting it on a car... i got a bunch around but not sure if they are any good.....any help here?
WannaBaShelby is offline
Old 07-18-2003, 04:55 PM   #2
90TurboShadow
the compressor side of the shaft... wiggle it see if it has any play at all... if it rubs against the housing then thats no good at all... it will eventually come apart... i think if it has in and out play in the shaft(i know ur thinking sick :P LOL) then i believe the bearings are bad.. hope it helps.
Matt
Old 07-18-2003, 10:16 PM   #3
check the blades too. if they're bent a little, it was hitting the housing. mine is like that, buy i cant afford the time/$$ for a rebuild, so its going back in for right now
BuRn__ is offline
Old 07-19-2003, 12:53 PM   #4
Engine: 2.2 turbo I
my uncle knows a guy that will rebuild a turbo for 75 bux.....
so .. i will eventually hit him up whne i find a decent car again....
Old 08-01-2003, 07:45 PM   #5
Engine: 2.2 turbo I
anyoneelse have an idea on how to test turbos????
Old 08-01-2003, 09:31 PM   #6
the way I do it..probably wrong.. but in the compressor side I push the shaft to one side (with moderate pressure) and with the other finger turn the turbine.. if it rubs on the compressor housing its time for new core.
works for me.
The Barron is offline
Synchronization fast and easy | Homes for Sale | Loans | Mobile Phones | Mbna
Page generated in 0.39835 seconds with 13 queries
