07-19-2003, 12:57 PM
BOV - how to?
My Ride: '92 Daytona Iroc
ok so i got 3 BOVs at home, know i wanna install one of them
but my question is:
how to install a BOV without destroying the stock airfilterbox and without changing to a cone filter?
that is my big problem
thanks guys
07-19-2003, 07:30 PM
Re: BOV - how to?
My Ride: 88 Turbo Lebaron
what kind of bov's? stock t1 bovs? u dont have to put them in the air box. just stick a little air breather clamped on it and you will be fine. i dont even run a filter on my bov (not alot of dust/sand flying around)
07-20-2003, 05:36 AM
i got one stock t1 bov,
one aftermarket bov for a 323 turbo mazda
one piston style bov
i want to install the piston style one, but i don't want to destroy the stock T2 airfilter box, know what i mean?
how do you mean, running without a filter?
07-20-2003, 01:21 PM
im not sure what type of bov the 323 turbo mazda has? bosch? is it larger than the stock t1 bov?
the reason the factory put the bov in the air box in the t1 is because they didnt want to have a seprate filter on the bov because when the engine is in vacum (when your not hammering on it) it will suck air in thru the bov.
if i had a stock t1 bov and i was trying to install it on a t2 id grab the hose from the turbo to the throttle body on the t1 motors which has the flange for the bov. id cut the hose short and put it on the upper i/c hose and clamp it on using metal pipes on each side to keep from crushing the pipe with clamps. then just get the correct diameter hose for the base of the bov and mount it to the stock flange using clamps. then hook the vac. line up to the tb. or other vaccum source. (im not sure if the t2 throttle body has a nipple for it and its just pluged or what)
07-21-2003, 04:12 PM
hmmm....
well, by removing my t1 bov from the shadow, i destroyed the hose from turbo to the tb
other ideas?:big grin:
07-22-2003, 04:27 AM
big thx, that was the one i needed "thumbs up
btw: on which nipple should i hook up the vacuum line of the BOV?
both of them are occupied, i will need a T-thing right?
my t2 has no stock bov, just a hose from the turbo(?) to the airbox.
07-22-2003, 10:30 AM
ah ok
and what should i do with the hose from the turbo to the airbox? just leave it blind?
07-23-2003, 07:35 AM
#12
well there's the big hose that goes from the airbox to the turbo, that gives the turbo air (inlet hose i hope  )
and there is another hose, a smaller one, coming into the airbox.
on a t1 engine i'd say, that this is the hose from stock BOV that's in the airbox.
you know what i mean? i'll take pics today and post them later.
07-23-2003, 09:59 AM
#14
My Ride: 1985 Shelby Charger
Engine: 2.2 T2
How about the breather hose from the PCV?
Most people get rid of the air box for an open K&N air filter & join the 2 intercooler hoses with a hard pipe that has a flange for a BOV, then cap the vacuum line from the cruise control & install a small breather filter on the end of the hose from the PCV.
Sorry, I just read the first post  I have seen people remove the section of the air box where the upper IC pipe goes through & install a hard pipe with a BOV.
07-23-2003, 11:19 AM
#15
Originally posted by lametec
Are you sure you have a TII?
The only other hose going into a TII airbox would be one for cruise control. This should come in from the front (side towards front of car). Other than that, there's air inlet, air outlet, intercooler inlet and throttlebody outlet.
i looked at it a few minutes ago, it's from the cruise control as you said...
yes it's surely a T2, cause they never sold other daytonas in austria
