Old 07-30-2003, 08:20 PM   #1
Installing a Talon BOV
Sean B.
OK, so I'm buying a Talon BOV from frostburner. The only problem is it's missing the mounting piece. Can I still use this BOV OK? And what's the EASIEST way to install it? I have no idea how to do this at all so the simplest method would be best. And would the abscence of the mounting thing be a problem? I just want the turbo to live a long, happy life....
Old 08-01-2003, 05:25 PM   #2
mounting flange
1/4: 13.650
Gary Donovan sells the flange on his site, as well as the gasket. I mounted mine on the lower intercooler hose, just before the intercooler. The flange has to be welded onto a pipe. I would suggest if you are running over 15 psi, to goto www.thedodgegarage.com and see gary's info on modding the valve for higher than stock boost levels. Trust me you need to do this if running more than 15......
Joe
firebaron90 is offline
Bankruptcy | Payday Loan | Bankruptcy | Loans | Loans
Page generated in 0.40310 seconds with 13 queries
