Old 08-03-2003, 11:05 PM   #16
My Ride: 86 GLHS 488
Engine: 2.2 T2
um... if you can blow through your PCV then it's bad...
When I'm bored at the junkyard I usually grab some and test them like that... only pocket the ones I can't blow through both ways.
sergio is offline
Old 08-03-2003, 11:43 PM   #17
My Ride: 88 Turbo Lebaron
lol so you get ones that u cant blow thru the way they are ment to flow? why not just cap the pcv valve system then. lol
OneFastBaron is offline
Old 08-03-2003, 11:56 PM   #18
Engine: 2.2 T2
you missed it... if you can't blow though it both ways then you still may be able to blow through one way.
sergio is offline
Old 08-04-2003, 12:50 PM   #19
so your saying the side its ment to flow its just hard to flow that way.
Old 08-04-2003, 05:41 PM   #20
My Ride: '04 SRT-4, '87 CSX
Engine: 2.4L I4
It's only supposed to flow one way. But make sure you're holding it in the right orientation when you test it. There's no spring; it depends on gravity to drop the metal ball into the seat.
CSX321 is offline
Old 08-04-2003, 09:22 PM   #21
yes I kept that all in mind. Also all the ones I have here have like a plastic plunger/plug thing.. no steel ball.
The Barron is offline
Old 08-04-2003, 09:51 PM   #22
Engine: 2.4L I4
Hmph. I've only got the one on the car here at the moment (just one from AutoZone), and it has a steel ball-like thingy, not perfectly round, in it.
CSX321 is offline
Old 08-04-2003, 10:01 PM   #23
thats what i got. ive never seen the plunger type....
Old 08-04-2003, 10:56 PM   #24
Re: Turbo owners; You HAVE a boost leak!
My Ride: No slicks Omni
Just a little tip for quicker,more consistant boost. In the below pic the hose that goes from the intake manifold to the PCV valve which "Y's"
Factory Mopar PVC valves are the only domestic ones that do not leak at all. Even TBI Mopar ones are posotively shut, aftermarket ones for turbo cars leak too. If you just want to add on in there grab a Toyota one from yard, they are strait and posotive locking.
You are correct, with 20 psi regulated air in shop a PVC valve sounds like a freight train with that small orifice opening.
russ jerome is offline
Old 08-04-2003, 11:36 PM   #25
AHHHH!! Thanks for the info! I'll have to get one at the dealer..and blow through it b4 i take it home....that should get an odd look! LOL!
Old 08-05-2003, 12:08 AM   #26
heh good thing thats what i got. "thumbs up
Old 08-07-2003, 11:41 PM   #27
mine already has a check valve in it. but i have a boost leak somewhere. sometimes when i'm in 3 and all the time when i'm in fourth, it goes to 14, then down to 5-7psi and slowly raises back up????? i'm gonna replace all the plastic vac. lines with new rubber ones, hopefully thats it.
glhs#064 is offline
Old 08-08-2003, 10:13 AM   #28
what about that canister in the front(pass. side) it has a couple vac tubes going to it and it has like a rubber diaphram in it..whats the scoop on this? Should I remove it and its tubes?
Myspace Proxy | Gaia Online Cheats | Song Lyrics | Car Loan | Loans
Page generated in 0.40996 seconds with 14 queries
