08-04-2003, 01:01 PM
Re: T1 with 1st gen BOV ?'s
My Ride: 88 Turbo Lebaron
Originally posted by joffficer
OK.. I have almost everything in my van now (IC, BOV CAI). I'm not sure which vaccum line to hook to the new BOV's top port. In the attached picture you'll see the two lines that came off the stock bov/air box.
The smaller one (on right) has a check valve, and was attached to the top of the stock BOV. I'm guessing this is the one I want to use, but what about the check valve. And what should I do with the larger line? I think it goes to the cruise control, and power brake booster.
the smaller one on the right is a source of vaccum for the bov. im not sure what you should do with the check valve (i dont have a aftermarket bov yet) the other hose should somehow be put into the intake. i drilled a hole in the side of the pvc intake pipe and used some epoxy to keep it sealed in.
