08-06-2003, 09:36 PM
Re: New to the whole turbo thing
My Ride: 88 Turbo Lebaron
Originally posted by ibemopar
So im new to owning a turbo. I have an 87 lebaron 2.2 turbo I. Unfortunetly the engines is toast. The oil looks more like mud but i might be able to rebuild. My question is, How do you tweak out a turbo to get more PSI? I know it has to do with the wastegate and if you get higher than ???? you have to get an intercooler. Can i tweak the stock 7 PSI turbo out? if so to what PSI?
well i have a stock turbo on my 88 (mitsu turbo, and no intercooler) and im running just below boost cut out so im running about 14. somthing psi. runs just fine..
u can get a intercooler anytime... but i wouldnt suggest going over 15psi without an intercooler.
all you need is a grainger valve to raise boost but you can only raise it to about 15psi then it will cut out, when you want more u need a custom calibration or zener diode to go beyond cut out then you will need more fuel, etc. u should have a boost gauge and a/f ratio gauge when rasing your boost any. www.thedodgegarage.com explains it very well.
