Old 08-06-2003, 10:41 PM   #1
Question Swap T03 to mitsu, which lines are different?
Turbo84Rampage
Got my T II computers today (thanks Dy Nasty) and gonna swap to a mitsu and new intake on the rampage's 2.2 this weekend. The motor is an 86 with a garrett, which lines are different from the garrett to the mitsu I will be installing (TE04H) There is an 88 2.2 w/mitsu at the junkyard, gotta go get parts before it goes CRUNCH in the evil yellow diesel powered turbo dodge killer
Old 08-07-2003, 02:25 PM   #2
My Ride: DOdge Shadow ES
Engine: 2.5l
Why are you swapping from a garrett to a mitsu? The garrett kicks royal butt on the mitsu. On my 2.5 the mitsu crapped out after 5000 rpm where the garrett just keeps going. Just a question.
DJ
turboshad is offline
Old 08-07-2003, 05:01 PM   #3
and a GOOD question it IS!!
Garrett to a mitsu?? Just say no!!
The Barron is offline
Old 08-07-2003, 05:50 PM   #4
Turbo84Rampage
The garrett is off of a pull through and is restricted by that little opening they call a compressor inlet. Besides, the 2.2 likes the smaller mitsu turbo better because it spools better on the smaller engine. The 2.5 in Slopar will be getting a garrett....because it falls on it's face with the mitsu and needs a bigger turbo. All i have available right now is a mitsu that will work with my intake, don't wanna buy any ghetto rigged inlet adapters for the T03 and don't wanna waste my TII housing on a 2.2.........you see?
Old 08-08-2003, 12:32 PM   #5
turbaron
I'm swapping from a mitsu to a garrett and will not be using my turbonation stainless lines anymore. Want to buy them?
Old 08-08-2003, 01:31 PM   #6
Engine: 2.5l
Does this mean you are swapping to a t2 initake? If so I wold think the old garrett with a few adaptor pieces and a bit of a compressor rotation would still be better. But each to his own. When I swapped mine over I changed all the coolant and oil lines. I went braided since it seems like most of the factory ones always fail. But if the ones on the car you are getting the turbo from are still good I would grab those and use them.
DJ
Old 08-10-2003, 03:38 PM   #7
How much for the mitsu turbo?
Prochargedmopar is offline
Old 08-10-2003, 07:48 PM   #8
turbaron
I'd sell mine for $100 minus shipping. It's been running fine on my car since I rebuilt the motor over a year ago. It's the original turbo with around 106k but doesn't smoke or have any problems. I run it at 14.5 psi but ran it with the wastegate unplugged for about 2 weeks with no problems. Here in Colorado it made around 17.5 psi unplugged. At a lower altitude it should be good for more.
Doug
Loans | Auto Loans | Plane Tickets | Bad Credit Mortgages | Payday Loans
Page generated in 0.40596 seconds with 13 queries
