Old 08-14-2003, 06:39 AM   #1
Mitsu Turbo.... but
So I have the head off right now to do a gasket change (someone put a felpro in there) and we got to thinking about that mitsubishi turbo, now would be a great time to swap it for a garrett.
Or, we could put a larger compressor wheel (housing maybe) from a 16g mitsubishi turbo and have a big, cheap turbo. I was wondering if this has been done before with results?
I've never heard of anyone trying this before and thought it might be a cheap way to get out of the mitsu turbo suckiness.
kmcdon3960 is offline
Old 08-14-2003, 01:17 PM   #2
i tried to build something like that out of TE04 Mitsu 13c and TD05 14b Mitsu but sizes of wheels/housings are different so I decided not to fuk with it and just install the DSM intercooler in place of radiator with some GOOD piping. I think TE04 Mitsu flows around 360 cfm at 15psi which, intercooled with intercooler sprayer, will produce somewhere around healthy 200 horses.
The smallest upgrade i would consider would be turbo flowing at least 500 cfm at 15psi
keep us posted bro
FlyinLow is offline
Old 08-16-2003, 12:14 PM   #3
are our mitsu turbos 13c units? someone told me once that it was a 9b. Anyway, I think the exhaust turbines on all mitsu turbos up to the 16g are the same, so you could probably just take the compressor half of a bigger unit and clamp it on the exhaust housing of our cars. I might just try it if I get the time
Old 08-18-2003, 04:16 PM   #4
swap
when I broke my #1 piston on my 2.5l I pulled the head changed the gasket threw a garret on it coated the pistons and ran 110 oct race fuel @ about 18 psi . That made a huge difference.
Mr P-body is offline
Old 11-12-2003, 11:32 PM   #5
BOZO
does a garret bolt right up to the 2.5 manifold was it a t3 ?
Old 11-13-2003, 07:47 AM   #6
The later TII garrets will bolt up, but the coolant lines are different.
supercrackerbox is offline
Old 11-19-2003, 10:32 PM   #7
r3mix
I'd look in the for sale section for a garret.
Old 11-20-2003, 07:55 PM   #8
Another thing I discovered replacing my Mitsu with an earlier Garret, the exhaust bolts won't line up. If you find a later one with the 2.5" swingvalve, it might be different, but my holes were probably 3/8" off on each side.
Old 11-20-2003, 11:14 PM   #9
OK....so since I'm getting my Garrett with no swing valve, and I'm adding a 3" SV I shouldn't have problems, right?
3Bar_Mopar is offline
Old 11-21-2003, 08:10 AM   #10
Hard to say. Send me the swingvalve and downpipe, and I'll test them for you!
Loans | Debt Consolidation | Build your own Dory Boat | Car Finance | Loans
Page generated in 0.46276 seconds with 13 queries
