Old 11-07-2009, 06:50 PM   #1
Lightbulb Turbo bracket????
My Ride: 91 gtc lebaron 2.5
Engine: 2.5 inter. t2
Do i need the brace that is conected to my t2 will it brake? cause i broke the bolt threaded in!!!! Should i replace it?? are there aftermarket ones???
9125lebaron is offline
Old 11-07-2009, 06:59 PM   #2
Re: Turbo bracket????
My Ride: 1989 Caravan
The brace that runs from your turbo to the block should be in place. It was there to prevent cracking. Did you break the bottom or top bolt?
newmember is offline
Old 11-07-2009, 07:11 PM   #3
i think the top???? the nut was connected to the brace? mabye just drill it out or replace? what would the diff be from top and bottom?
Old 11-07-2009, 07:30 PM   #4
Bottom uses a larger bolt and threads into the block. Top has the threaded area on the brace. How much of the bolt is sticking out of the threads? You may be able to take of the brace and get on the remains with some pliers and get it off. Or possibly weld a nut to the threads and back it out.
Page generated in 0.17363 seconds with 9 queries
