09-29-2003, 04:32 PM
87DTNA - good catch on not needing a BOV. Yes since this is a
pull-through system on an 85 it shouldn't have a BOV,
however again if swtiching to a blow-through system
you'll have to upgrade your turbo
outlet/computer/BOV/TB/Manifolds..blah..
Um...the MP computers ONLY seemed to raise the max boost level
from stock to peak (ie. 7 to 11PSI). Aside from that there is much debate as to fuel/spark tables. As with most people on this board, unless your going for a custom calibration (3 bar map/40+ injectors) there is NO need for an aftermarket computer which can be accomplished with a MBC and cut-out raiser. Much cheaper and the same job. Which ever route you go you'll need the MBC at some point in time.
All the best.
Peace
