Old 09-28-2003, 07:10 PM   #1
I keep overboosting?
My Ride: 04 Impreza
Engine: 2.5 SOHC
Images: 3
it's a stock 89 Shadow ES. Well, almost stock. it has a 2.5 exhaust all the way back, no cat.
It will boost all the way to 15psi, then keeps hitting the cut-out point. I dont hear any detonation, and my spark plugs are reading fine. Is there someting wrong with my turbo, or the restirctor?
Moof is offline
Old 09-28-2003, 07:50 PM   #2
I would check your vacuum line going to your wastegate. Maybe your exhaust has burned a hole in it, or it cracked from drying out.. Something is keeping your wastegate from sensing boost.
Ubmbass is offline
Old 09-29-2003, 01:47 AM   #3
My Ride: 04 Impreza
Engine: 2.5 SOHC
Images: 3
sounds like a good idea. I'll check in the morning before work.
Well, sometimes the boost works well. it'll taper off around 10psi.. then if I let off the gas and stomp it again, It'll jump to 14-15 and cut out.
Moof is offline
Old 09-29-2003, 01:54 AM   #4
since the car has a mitsu and you've upgraded the exhaust i believe that your just experienceing some nasty boost creep.
89daytonaTII is offline
Old 09-29-2003, 01:21 PM   #5
My Ride: 04 Impreza
Engine: 2.5 SOHC
Images: 3
would a blown head gasket cause boost creep?
Just wonderin', cause after last night during a spirited run, I started smelling coolant
EDIT: hahaha i'm stupid. My coolant reservoir tank has a split in the bottom and is dripping coolant onto the block. "thumbs up
Moof is offline
Old 10-14-2003, 09:30 PM   #6
You need a cutout raiser on your MAP sensor line, your hitting computer cut-out at 14.5 psi. Get one at Dawes devices, they work awesome!!!!!
Old 10-15-2003, 09:34 AM   #7
My Ride: 84 rampage
Engine: 2.2L T3
if you go that route, just make sure you have enough fuel to go with that added boost!
Mike Radowski is offline
Old 10-15-2003, 11:17 AM   #8
Right Clickhere33, make sure you have enough fuel or back down on your boost so you don't hit cutout!
Car Credit | Credit Cards | Buy PSP | Advertising | Advertising
Page generated in 0.35677 seconds with 13 queries
