11-19-2003, 07:29 PM
I would imagine that the turbo needs to be at a certain temperature to keep the bearings from wearing prematurely, just as the rest of the engine needs to, so getting it too cold might be a bad idea. the addition of a whole engine thermostatically controlled cooler (stick yer head under the front end of a RX7 in the junkyard next time youre there) would do nicely, as suggested.
as for water, it does basically nothing while the engine is running, and boils anyway after you shutdown, so cooling it off would have no effect on anything, except to provide more points of failure in the cooling system (thats a bad thing).
