Originally posted by 4sfed4
When I did the "reverse guessitimation" using dyno charts and the compressor maps, etc using your spredsheet, I am getting VE's well over 100%.
For a 12 psi dyno run, here is how the numbers worked out---
RPM 7,000 6,000 5,000 4,000 3,000 2,000
VE 100% 130% 140% 145% 110% 100%
I have no idea whether this is realistic or not!
This is kind of unwalked territory for myself, but let me take a stab at it.
100% VE of a n/a 2.0L engine is 2.0L of air. Normally stock tuning does not allow for 100% but a bit less, especially on heads like 2.2/2.5. You can achieve almost 110% VE on race n/a motors with properly valve overlap, head flow, exhuast flow, etc, etc, etc.
If you then factor in boost, say 12 psi of air of a 2.0L, and *lets say* it equals the equivelent of 2.3L of air at atmospheric pressure and you really had the equivelent of 2.3L of air in the engine, then it would be 100% VE. If you have 2.2L of air, then you would be at 95.6% VE.
This actually automatically compensates for air temps, psi, comp efficency, adiabatic efficency, etc to form air density and so your numbers seem right on if you were comparing it to your origional airflow. So to summerize it, if you are at these atmospheric conditions and I have this PSI, I should have this much air in my engine called X. But I really have Y. So now VE = Y/X.
With all that said, maybe something like this????
VE 82% 89% 93% 96% 84% 82%
Frank
