12-17-2003, 09:52 AM
#15
My Ride: 1991 Daytona Shelby
Engine: 2.5L
Since this is as good as thread as any, here is my map for the turbo I am putting on my 3.0L. (demand lines are at 2500 and 3000 to 8000 rpms respectively left to right).
The compressor wheel you are looking at is a DBB GT37. I will be matching it up with a GT31 turbine that contains a GT30 wheel which creates a GT3037. This should compensate for the lower flow that my engine has when compare to better flowing 3.0l's that use the full gt37 package or the super large a/r of the gt3037 setup.
The gt3037 turbine a/r's availabe are .63, .82, and 1.06. I probably wont decide which of the two smaller a/r's to use until i have recieved flowbench numbers from my head work that Brian Slowe will be doing shortly.
The compressor map is a different story. I want an all around car... road race (& autocross), street, and drag - in that order. So initially I was thinking that i would want the 76mm (or T04) housing, however, i would sacrifice the high end that I feel that this motor can grab (with custom manifolds and intake). So should I go with the 82mm? I dont know how the 82mm would effect me with my autocross and low end. The other thing to note that in the autocross/road racing, I will be barely pushing 25psi, but on the drag, 30psi. And again, another aspect to note is that the gt3037 setup flows less at high end then the full gt37 setup, so will i even achieve the high end of the 82mm compressor?
Plain and simple, its all a mess :big grin:
Any suggestions would be golden.
Frank
