11-23-2012, 06:33 PM
#41
Re: ATP Wastegate Swingvalve?
don't be bashin the Mini
My Ride: 89 woody Voyager
Engine: 2.5 upgraded to T2 Status and converted to a 5spd
So if you look at the list I made at the top of the post you will see that it calls out for the ZF pump with all the mounting hardware and hoses. . . that means that the hoses that are used originally with the zf pump will be needed when using the zf pump for your aplication. It also means that the mounting hardware originally used with the zf pump will be needed in your application as well. As far as the down pipe goes, with any vband style flange in turbo or non turbo applications you will need a flex joint. If your looking into doing this, you should have already found this out by either looking at the pics in my build thread and thinking, "man for some reason that exhaust doesn't look like my doughnut style, Maybe I should look into a vband style down pipe that will go with my vband swingvalve", or by looking at the pics posted earlier in this thread and thinking the same thing. You get a 3" vband flange, attach a 3" pipe to it that has a 4.5" radius bend in it, put a o2 bung in there somewhere down the line from the turbo so as not to melt your o2 sensor, and also put a flex joint in it. Put the flex joint before the o2 or after, I'm sure it doesn't matter.
Learn how to support this site and gain access to VIP areas by going to the
