TIII head question? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > Engine - Turbo & Block
Old 11-17-2012, 11:32 AM   #1
TIII head question?
Garrett Booster
My Ride: '84 shelby charger
MarkassBauer is keeping the peace
can i put a 2.2 dohc head on a regular 2.2 block???
MarkassBauer is offline
Old 11-17-2012, 11:38 AM   #2
Re: TIII head question?
Level 3 Supporter
4Daytonas's Avatar
My Ride: 84 Turbo Z, 91 Shelb
Engine: 2.2-2.5
Feedback: (30)
4Daytonas is keeping the peace
A T3? Yes. A Neon? Well yes with with some Block Mods.
4Daytonas is offline
Old 11-17-2012, 11:46 AM   #3
kills more cars than rust
2.2lanceres's Avatar
My Ride: lancer
Engine: 2.5 .20 over
2.2lanceres is keeping the peace
you need to make a block off plate for the distributor
2.2lanceres is offline
Old 11-17-2012, 11:48 AM   #4
Daytona Junkie
He can also use the dizzy if he wants.....
Old 11-17-2012, 12:54 PM   #5
Level 4 Supporter
DetroitTurbo's Avatar
My Ride: 1985 Daytona
Engine: 2.2l
DetroitTurbo is keeping the peace
What is the dizzy?
DetroitTurbo is offline
Old 11-17-2012, 01:02 PM   #6
Garrett Booster
Originally Posted by DetroitTurbo View Post
What is the dizzy?
the distributor i think lol. does it not have height clearance with that head? cuz i was wonderin about that... if it doesnt, then what do i do for a distributor??? and yes im talkin a TIII 2.2 head not a 2.0 or 2.4. i would just get a hans head but the only one i can find is bare and where the F@#* would get valve train parts for that?!?! lol
Old 11-17-2012, 01:17 PM   #7
Daytona Junkie
Yes lol dizzy is distributor. Its been done before many of times
Old 11-17-2012, 02:04 PM   #8
Dr Doom
Dr. Johny Dodge's Avatar
My Ride: RUSTY DODGES &FORDS
Engine: 86 T1
Feedback: (16)
the t3 would have a cam position sensor on the head and a crank position sensor on the bellhouseing - meaning you would need the flywheel that triggers the sensor , and a sensor on the trans - not sure if the sensor can be added to the trans if it didn't orig have one
but someone here should know the details on that
these 2 sensors thak the place of the pick ups in the distribuator
if you could find a core plug like in the water jackets that fits the hole for the dist it would prob be much easier than trying to make somthing to cover the hole too
check out my for sale thread Toronto area body, interior, mechanical L,G,K
http://i36.photobucket.com/albums/e9/bubblebob88/0motm9.jpg
Dr. Johny Dodge is online now
Old 11-17-2012, 11:18 PM   #9
Garrett Booster
as long as theres room ill run the distributor. F@#* cam and crank sensors, after all it's a carb'd '85 hahahahahahaaa!!!
Old 11-17-2012, 11:39 PM   #10
My Ride: 91 Spirit R/T,
Engine: 2.2 TIII
Feedback: (6)
rx2mazda is keeping the peace
no room to run the dizzy with the TIII intake. most guys run the dizzy off the exhaust cam. gotta have the right electronics to run the TIII.
rx2mazda is offline
Old 11-18-2012, 12:15 AM   #11
Garrett Booster
mind you my intake is gona protrude straight out from the side of the head cuz im running a carb. im gona get my 2.2 carb manifold welded to the TIII intake manfold flange after some cutting so it'll bolt up to the head. so the manifold wont wrap downwards like the stock TIII. Has anyone else put a dohc TIII head on a carb'd 2.2??? just curious...
Old 11-18-2012, 08:29 AM   #12
Level 4 Supporter
Engine: 2.2l
If you are carb'd and not fuel injection, there is nothing for the computer to know about the timing for fuel, because the carb does all the work. If you run a HEP and it is timed correctly it should be fine. Granted this is all guesswork on my part but I cant see a carb'd car needing any kind of crank or cam sensors if theres no variable valve timing or sh*t like that. My '66 didn't have a computer, or any positioning sensors.
Old 11-18-2012, 08:58 AM   #13
csx274 is keeping the peace
Another question, what will you do to bring the compression up? T3 pistons are unique with the valve reliefs, and I wouldn't think anyone makes pistons for a n/a t3.
csx274 is offline
Old 11-18-2012, 04:22 PM   #14
Garrett Booster
im using an n/a 2.2 block w .060 over flat top pistons.
Old 11-18-2012, 05:26 PM   #15
Engine: 2.2 TIII
Feedback: (6)
ROTFLMAO! .060 flat tops and a carb with a $1k+ head.......blasphemy! Please post pics when completed
rx2mazda is offline
