the for sale section here will probably be your best source of parts without question
if you don't need the
egr system for emissions tests / checks where you live , you can make the turbo from the parts you already have if the 88 turbo is a garret
you may need a new gasket for the houseing but if your 85 turbo is really freash , maybe not
you first need to swap the 88 compressor houseing onto your 85 turbo
- that will eliminate the elbow and
egr valve on your 85 garret
if that 85 turbo is freash , you may be able to get the bolts out of the exhaust houseing so you can swap it for the 88 without the
egr tube taped into it
- remember there is 1 bolt hidden inside the ex houseing too !!
- but an 89 exhaust houseing would be much better as they fit to a 2 1/2 inch down pipe
(pre 89 is 2 1/4 - some 88's look like 2 1/2 's but they're not really when you look inside them )
BUT , don't try to hard to get the bolts out - after some use they usually snap off - so if the bolts don't want to turn easy you might be wise to just remove the
egr tube from the ex houseing and block off the hole
you could get away with just cutting it off , leaveing enough tube to pinch and weld it shut
if you can find an 88-89 engine harness - all of it and a dash harness , that's the easy way to mod the electrical system - though some mods may be needed to the rear body harness and door harness to plug into the 88 dash harness as 86 & up got newer design connectors - so you might have to swap a few connectors over to the newer style
an 88-89 T1 harness will do if a T2 one dosen't pop up easy - all you will need is to add the intake temp sensor wireing
to make the gromit for the firewall pass through fit where your firewall conector is now , all you need to do is make the hole round - if you measure the engine compartment to das harness conector diagonally from corner to corner , that will give you the correct size for the gromit that goes into the firewall where your original firewall conector was/is
if you go for the 88-89 harness make sure you get the trans/starter harness and front of motor harness with it
if you go for an 87 harness - same applies AND , I think you would still need to change the dash harness simply because (if I remember correctly) the firewall conector changed from 85 to 86
an 86 dash harness will work in your dash too(with 87 engine harness) but you still may need to to the mods I mentioned above as 86 was the year the new conectors got put on the electrical system
you're also gonna need the 87-9 vacume solonids and
map/baro sensor
the 86 &^ got the bigger distributor
the smaller 84-85 one will not work with the 86-89 wireing and computers
personally , I've found that the 88-89 electrical systems seem to be better than the earlier stuff regardless of what motor is in the car - and, the 88-9 system will leave you with better or more options for custom calibrations than the older logic / power module deal
and , yes an 88-89 lebaron T1 engine compartment harness will work - all you need to do is add the intake temp sensor wireing to it
- a lebaron dash harness will leave you with non functioning power mirrors and console wireing may be routed differently in the car too
if you go for the 88-89 harness's you will want to get the 88-9 brake light switch and it's bracket too
you will also need to change the circit board on the back of your boost gauge / message center too - the plug changes
also , you may need to swap the plugs from your cluster to the 88-9 dash harness
or swap an 88-9 cluster and boost gauge / mess center in and loose the graph paper design on the 84-6 dash
