Turbo - Intake side shaft nut cannot remove - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > Engine - Turbo & Block
Old 01-09-2013, 09:08 AM   #1
ENTER 4 MAY COTM!
yellonoma's Avatar
My Ride: 89 Daytona Shelby TT
Engine: 2.5 TII
Feedback: (7)
yellonoma is keeping the peace
Rebuilding a T2 turbo, everything came off like gravy except the last part.. cannot get that shaft nut off the intake side. Any tricks or advise? If I come on to it anymore i'm going to snap the shaft, added propane heat but no luck so far.
I tore down three T1 turbos for practice leading up to this one with no issues at all, now the one I need is giving me this trouble
And no.. I am not/will not send it away for rebuild
yellonoma is offline
Old 01-09-2013, 09:24 AM   #2
Re: Turbo - Intake side shaft nut cannot remove
4 L-bodies is keeping the peace
Many aftermarket and newer turbine shafts are left hand threads. Are you turning the wrong way?
4 L-bodies is offline
Old 01-09-2013, 09:26 AM   #3
Level 2 Supporter
My Ride: STI
going4speed is keeping the peace
I did not know it was possible to rebuild ones own turbo...that is awesome!!
How about leaving it in the freezer for a couple of hours and then try break it lose?
going4speed is offline
Old 01-09-2013, 09:56 AM   #4
ENTER 4 MAY COTM!
yellonoma's Avatar
Engine: 2.5 TII
Feedback: (7)
All the T1 garrett's and mitsu's were right hand, would be good to know though for sure on the T2 Garrett...
Old 01-09-2013, 10:22 AM   #5
ENTER 4 MAY COTM!
yellonoma's Avatar
Engine: 2.5 TII
Feedback: (7)
Got it off successfully.. finally, just propane and patience. It is right hand turn to avoid any confusion, thanks to those that pitched in.
Old 01-17-2013, 12:26 PM   #6
Garrett Booster
My Ride: Kia Rio/ 90 Spirit
Mr. Stroker is keeping the peace
Where did you get your rebuild kit from? The only reliable place seems to be gpop shop
Mr. Stroker is offline
Old 01-17-2013, 12:46 PM   #7
ENTER 4 MAY COTM!
yellonoma's Avatar
Engine: 2.5 TII
Feedback: (7)
Yes G-pop is where bought mine from, $49 for a basic kit isn't unreasonable I think.
Old 01-17-2013, 03:37 PM   #8
My Ride: 87 New Yorker t1
Feedback: (7)
D3NT is keeping the peace
you install that turbo yet? would like to know how everything went for you
D3NT is offline
Old 01-17-2013, 05:49 PM   #9
ENTER 4 MAY COTM!
yellonoma's Avatar
Engine: 2.5 TII
Feedback: (7)
Wont be installed till the spring, but I dont se there being any short term issuses, putting it back together is very simple, as long as you mark the position of the intake compressor wheel
Old 01-17-2013, 06:51 PM   #10
Feedback: (7)
no balancing? how much boost you going to run?
D3NT is offline
Old 01-17-2013, 07:24 PM   #11
My Ride: 87' GLHS & Turbo Van
Feedback: (8)
GLHS #26 is keeping the peace
I have had that question too, but again if it was fine before the rebuild changing the bearings doesn't change the balance does it??
GLHS #26 is offline
Old 01-17-2013, 07:32 PM   #12
CHAMPION OF THE LOG
onerippinturbo2's Avatar
My Ride: 85 shelby charger
Engine: 2.2l sohc bored.20
1/4: 12.550
Feedback: (41)
onerippinturbo2 is keeping the peace
it could be argued that removing the wheel from the shaft could/can/does change the balance, some do balance( i do) others dont and dont have any problems, it's a gamble.
onerippinturbo2 is online now
Old 01-17-2013, 08:56 PM   #13
ENTER 4 MAY COTM!
yellonoma's Avatar
Engine: 2.5 TII
Feedback: (7)
A gamble im willing to take, for 50 bucks and I only plan to get 1 or two summers out of it before the motor gets yanked out, it is only a sunday driver. I am running 14 psi
Old 01-18-2013, 11:52 AM   #14
Level 1 Supporter
cawcislo's Avatar
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
Feedback: (8)
Images: 4
cawcislo is keeping the peace
I wouldn't worry about it. It should hold up just fine. I bought a Super 60 turbo probably 5 or 6 years ago and rebuilt it. Slapped it in the car and it's been just fine running 18 psi over and over (no BOV either - haven't got around it installing it). The turbos take a beating and keep on ticking.
cawcislo is offline
Old 01-18-2013, 12:11 PM   #15
ENTER 4 MAY COTM!
yellonoma's Avatar
Engine: 2.5 TII
Feedback: (7)
Ironically I have more radial (side to side) shaft play after the rebuild kit, it's not hitting the housing but dam close to it, I am feeling timid about throwing this in the car now...
