01-24-2013, 09:29 AM
Re: Rear camshaft seal popped out of its seat, oil all over
Should Buy Another E30
My Ride: Daytona Shelby VNT
I always torque the cam before installing the seals. No need to disturb the valve cover or cam when replacing seals. The sealant used, if any, for the seal installation can be personal preference whether it is the FSM listed sealant(never a bad choice), or other(just don't use super glue people or other completely ridiculous chemicals). On the front cam seal, I don't use any RTV, just line the lip with a light coat of motor oil. For me, my method is tried and true. I have installed dozens of rear cam seals with ultra grey RTV, on rebuilt engines or high mileage engines. It keeps them in place and the old RTV is easy to clean off the next time you must perform a service that requires removal/install of that rear seal/cap. I suppose I could start buying Permatex #2 or Permatex Aviation Cement and those would work excellent. I just always keep ultra grey around my shop and I have never had a problem using it for this application. There are a couple different ways that you can do this and each method will work. Simple operation.
