Old 03-14-2004, 12:20 AM   #1
unplugged wastegate line
My Ride: 86 Turbo z,73 duster
I have been reading about unplugging the vaccum line betwen the turbo and wastegate and on a mitsu turbo u will see about 18 psi. How does this work?, I realize I sound like an idiot but I'm just trying to learn as much as I can!
stampederunner is offline
Old 03-14-2004, 06:39 AM   #2
My Ride: 1991 Spirit R/T
That method relies on exhaust backpressure to open the flapper in the wastegate. It works very well as long at the boost you get is what you want! So, be careful.
4sfed4 is offline
Old 03-14-2004, 09:36 PM   #3
My Ride: 1987 Daytona Shelby
Engine: 2.5 16v
yeah but without proper fuel you can blow **** up, so I wouldn't recommend even trying this if you're a newbie go too www.thedodogegarage.com and read the turbo section over completely, then when you are done, READ IT AGAIN and then when you finish that READ IT ONCE MORE! then if you have questions READ IT AGAIN cause it's all there my friend
Garret is offline
Old 03-14-2004, 10:59 PM   #4
I might be a newbie to turbos but not to high performance engines I fully understand that I must have enough fuel to run high boost. I have +20 injectors and a 5th injector so im running really rich right now at 14 psi. I think that only 5 more psi would probably get me closer to a correct air/fuel ratio (correct me if im wrong).
Cause with the mitsu unplugged it will only boost to 18-19 psi correct?
Pacotes TurĂ­sticos | Debt Consolidation | Credit Cards | Unblock Myspace | Direct TV
Page generated in 0.26182 seconds with 13 queries
