Old 03-22-2004, 10:49 PM   #1
lower boost w/ granger?
My Ride: 73 roadrunner
Engine: 340 c.i.
My brother got his turbo, manifold, and down pipe from a guy used. The turbo is internally gated and in "stock" form allows 14psi. My brothers motor woulnt handle more than 7 psi w/ his stock internals. If he gets a granger valve can we lower the boost to 6-7psi?
I thought I read some where that you can but before he orders one I figured I'd ask. Thanx for any info my brother appreciates it and so does his motor
Joe
Super60Dodge is offline
Old 03-23-2004, 11:20 AM   #2
frightless
No. Turning the g-valve down will only open the g-valve sooner, but will not open the wastegate sooner. If you want lower boost, you must change the wastegate.
I say let it blow, and then build the crap out of it.
Old 03-23-2004, 01:17 PM   #3
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
i assume the motor is not a mopar? gus's site had some info on adjusting the arm of the wastegate actuator if the arm has an adjusting nut and threaded rod. if not, the site shows how to make it adjustable. www.gusmahon.org
Brian
Aries_Turbo is offline
Old 03-23-2004, 10:18 PM   #4
Engine: 340 c.i.
That is correct sir! It's a Honda B16A in my bro's Del Sol. AKA the torquless wonder I just found out it's a 16G mitsu off a first gen DSM. No shaft play and it looks clean.
It's funny before I logged on and read this I told my brother abought Gus's mod. it looks like it's the easiest way out.
Thanks man
Joe
Old 03-23-2004, 11:27 PM   #5
Engine: 2.5L T2
no problem. good luck on the honda. my buddy has a 2000 civic ex with a greddy setup (from ebay) on the d16. its not too bad though yeah it doesnt have any torque.
Brian
Old 03-24-2004, 10:25 PM   #6
Engine: 340 c.i.
His car doesnt run to bad it's just week off the line my civic ex will match him in 1st but getting into second the dohc takes over. He should run 13's pretty easy with the kit @ 7-8psi. His car is killer on traction and is got alot of carbon fiber to lighten the load.
Well thats enough honda babel for the week! Thanks again
Joe
Debt Consolidation | Actress | Free File Hosting | Free Advertising | Free File Hosting
Page generated in 0.58315 seconds with 13 queries
