03-28-2004, 10:47 PM
My Ride: 73 roadrunner
Engine: 340 c.i.
I wouldnt go over 18 w/ a T1 even though it's been done you will snap the small end of the rod like I did on my old Tona. Dont go over 12psi w/o an intercooler
Joe
04-01-2004, 04:28 PM
Authorized TD Vendor
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
Turn it up until it blows and back it off 1 psi.......
Wallace
91 Spirit R/T
11.686@120.89 mph
04-01-2004, 04:40 PM
Resident piston cracker
My Ride: 92gtc vert
Engine: 2.5 8v
04-27-2004, 10:03 PM
#14
what about a je piston motor w/ billet rods and a forged crank in a 89 common block.think it will handle 42+psi(intercooled of course)
hah, well the thing is, it's not about the boost, its how the engine uses it. 18 or 30 or 42 psi is piddly **** in the grand scheme of the combustion pressures the engine actually experiences. what really determines how much boost an engine can take is how well it utilizes the boost. if you have a stock ghead with stock manifolds and a ****ty intercooler and ****ed up cam timing and are only making 350 hp at 42 psi of boost, sure, it could handle it. if you have a good flowing efficient top end like a hybrid conversion or t3 and would probably make 700 hp on 42 psi, no it cant take it.
thats why it depends so much on the details of your setup. assuming you had the ability to properly take advantage of that amount of boost, i dont think a near stock bottom end could handle it.
