04-05-2004, 03:53 PM
I would definatley replace the coil, its probably the original. Any stock replacement or one step up will be fine. What type of wires are you using. I hope a high quality like Aurora! MSD is ok, but there cheaply made. What type of plugs, standard or platinum? I wouldn't use NGK regulars, they don't seem to last very long. Bosch or Autolites regular seem to last, also go one step colder!
Got any pics, that sounds like a sweet ride?
"thumbs up
04-05-2004, 09:36 PM
I will check them out. I am not saying NGK plugs are bad, just saying that they were alot faster than the other brands.
04-06-2004, 08:45 AM
My Ride: Daytona
Engine: 3.0l 181
i also have a turbo 3.0l which i had for a short time and it went boom. now im rebuilding it with all forged components. when is it missing? what rpm and gear? id go with msd btm unit personally.
chief
04-07-2004, 11:09 AM
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
what kind of instrumentation do you have? egt? a/f?
good luck
Brian
04-07-2004, 11:43 AM
My Ride: 1995 Dodge Avenger
Engine: 3.15L
Run a colder plug.
Check the A/F or EGT if you have it and make sure you are running decent numbers. At 12psi on my 2.5 I kick upwards of 1560 on the EGT, make sure you have plenty of fuel to compensate.
04-08-2004, 12:35 AM
My Ride: Daytona
Engine: 3.0l 181
u have the same problem as i did before my pistons decided to let go. good luck
04-08-2004, 06:50 AM
#12
My Ride: 1994 Dodge Shadow
Engine: 3.0 6G72
lower compression, perhaps. i heard these engines only like up to 10lbs of boost until bad things happen, as they do run a slightly higer compression than most production and modified turbo cars. this is why turbo kits for like hondas only run 6-8lbs. id suggest beefing up the bottom end and lower the compression to go for more boost.
04-08-2004, 11:28 AM
#13
How Did you do it?
My Ride: Daytona base
Engine: 2.5 Turbo
Hey, How did you work out the issue with the rear exahust manifold??? I have a 3.0 in my daytona and really need boost, badly!!! I was thinking about supercharger, but I would rather go turbo. Very nice design on the x-over pipe where the turbo mounts, who made that??? Please give me details!!!!!.
Steve
90 Daytona v6 5spd (NEEDS BOOST!!!!)
04-08-2004, 12:41 PM
#14
What I did for the rear exhaust manifold was use the stock one, cut off the back, gut out the internal walls with a torch, and then weld a sheet of steel across the back to close it off. This way I knew that everything would fit right. I have a flange and plan to eventually fabricate a better manifold, but this works fine for now.
I made the crossover pipe by setting up a wooden jig using the stock crossover piece. I then just kept cutting and fitting the 1 7/8" exhaust piping from Summit Racing until everthing fit right, and tacked it in place. My friend's dad is a pro at TIG welding so I had him finish it up. Getting the pieces to come together right was the hardest part, but we eventually got it to work.
The rest of the exhaust/intercooler piping was basically the same process of tacking exhaust pipe pieces together until they fit right, and having them TIG welded shut.
I don't think the compression is really a problem on these engines, especially when intercooled. If you ask me, they're ideal for boost at 8.8:1. Most honda engines are 10:1 + and run the same amount of boost as I do and are fine.
04-08-2004, 12:52 PM
#15
Engine: 3.15L
What are you running to compensate for fuel? Vortech FMU etc? To me it sounds like you are running lean, with the gap at .030 it should be fine and not blowing out the spark unless your coil is that weak. I run .033- .035 gap, anything less feels like crap, anything more and I make the cylinder temps shoot up under a hard pull.
