Old 04-06-2004, 06:00 PM   #1
87DTNA
I got a turbo here with the water line connection busted off. I've tried an ''easy out'', but it's in there good. Any idea's on how to take this out short of drilling and re-tapping?
Can I try heating it up with a torch or will that hurt the bearings or seals?
Old 04-06-2004, 10:41 PM   #2
It shouldn't hurt the bearings or seals, think of how much hotter the turbo gets than a torch will get. Are you using a good penetrating oil? I may have another solution if that doesn't work, but you may have to retap the hole when you're done.
1985ShlbyChrger is offline
Old 04-07-2004, 10:40 AM   #3
ShelbyZTurboII
I'm in the same boat you're in except with a swingvalve bolt. I was drilling it out and I got an easy-out in there with a good bite, now the easy out is snapped off in there too I am just drilling and re-tapping. (the way the swingvalve bolt was drilling out in the first place, I should have done that to start!)
Old 04-07-2004, 05:20 PM   #4
87DTNA
Well I guess it's time to break out the drill and tap and dye set. Thanks guys.
Loans | Facebook Proxy | Credit Cards | Debt Consolidation | Fuente De
Page generated in 0.31935 seconds with 13 queries
