05-29-2004, 12:46 AM
My Ride: 91 Spirit R/T
Engine: TIII
Actually assembling a turbo isn't the tough part. It's the balancing that's needed. You can liken it to wheel/tire balancing. Youcan get a nasty vibration from it being off only .5 oz and it doesn't even spin 1000 rpm. Now how important is the balancing when you have things spinning 175,000 rpm? Yeah, just have a reputable shop do it.
05-29-2004, 11:06 AM
My Ride: 1987 Shelby GLHS 189
Try .5 gram.
05-29-2004, 10:07 PM
My Ride: 1991 Spirit R/T
Originally posted by shelbyluvinfool
No it's fine, I'm looking for horror stories of people screwing up their turbos.
Theoretically, if both the compressor wheel and turbine wheel/shaft are balanced perfectly alone, they should be able to be assembled in any position and not rebalanced.
However, that is not reality. If it was, Turbonetics, Garett (and all the rest of the major manufacturers) wouldnt waste the $ on the balancing machines.
I would take a serious dollar and "sense" look at what you are trying to accomplish by assembling your own turbo. I am as cheap as they come, but in the end, you may not save much and will have no warranty.
05-29-2004, 10:59 PM
My Ride: 85 shelby charger
Engine: 2.2 liter I-4
There are several places around the country that will dynamically balance your turbo for you once you put it together and thats the way to go. Just build what ever turbo setup you want then send it off to be balanced. Chris at TU would probably be able to do it or point you in the right direction, and relentless used to do it but not sure if thats still the case since gary is operating on a smaller scale.
