Old 05-31-2004, 06:13 PM   #1
boost?
hey guys ive got alot of help from you all on here and i was wondering if u could help me out with some ways to get my car faster. i just recently installed a 1g BOV and im now running about 10 psi. any ways to reduce turbo lag? i raced a 240 sx the other night i just beat him by a car and i want my car faster. and i know that most of you guys on here have super fast cars and your all my role models...haha well any help would be great. thanx alot
TIIdaytona is offline
Old 05-31-2004, 07:56 PM   #2
My Ride: 87 Daytona Shelby Z
Engine: 2.5 Turbo
What do you have on the car right now?
Start with the the exhaust, 2.5 or 3". Then turn the boost up some more. Then maybe a better intercooler, you probably wont need a better one yet though. A drop in K&N is abvious. Maybe a cone if you wanna custom make a hose to the TB.
Orangetona is offline
Old 06-01-2004, 12:48 AM   #3
My Ride: 90 stang, 86 stang
Engine: T.T521", nitrous351w
dont forget injetors, stock injectors n cal's normaly wont be ne good over 15 psi ive found that out the hard way a few times if u dont wanna chane injectors add a few (two) cold start injectors with alchol injection and control them with a hobbs switch to turn on around14 psi for one and ne thing over 18 turn o the other on
Derrick
igotaneed4speed is offline
Old 06-01-2004, 02:58 PM   #4
ive got a 2.2 TII and i have a k&n cone filter and a 1g BOV and i have straight pipe and a magnaflow muffler. thats all ive done so far. and ya i was thinking of turning up the boost.. what all do u need to add more? like injectors and shizzle but is there naything else u need to do? and also i need to know how to turn it up
Old 06-02-2004, 05:28 PM   #5
Engine: 2.5 Turbo
It looks like you have been around for a while so you should know what a grainger valve is. That manually turns up the boost. So you can up the boost by that. Other than the injectors or adding the extra injectors your stock fuel system should be fine unless you are making a pretty good amount of power.
Old 06-02-2004, 06:53 PM   #6
My Ride: 89 Caravan LE Turbo
Before you go any further, you need to buy and install a good air fuel gauge if you dont already have one. The brand I bought is called a Dawes device and is VERY bright. I purchased mine from Chris at www.********************
AZTurboMini is offline
Old 06-02-2004, 07:29 PM   #7
ya i klnow what a grainger valve is but i dont really know how to install one or anything...ya i wanted to up the boost because when in stalled the BOV i think i lost a couple psi and it seems like i have much more lag then i did before.. are there any ways to prevent lag or like make it less obvious or whatever? how come the air fuel guage?
Old 06-02-2004, 09:42 PM   #8
I am not great at explaining things but here we go...
When you turn your boost up you have a chance of running lean on fuel. When you run lean under WOT it only takes a splt second to toast your motor. Thats where the gauge comes in handy. If I see a red light at WOT I know to back out of it and either check for a problem or know the fuel pressure needs to be adjusted. You can take a chance and not run one but a $50 device could save you a ton of cash = new motor.
Old 06-02-2004, 10:48 PM   #9
ya k ill check into that thenbut first i need to raise the boost.. ha... also before i forget about this.. how does the air fuel guage get installed?
Old 06-02-2004, 10:57 PM   #10
By you or someone that knows how to wire it! 3 wires...no big deal.
Old 06-02-2004, 11:14 PM   #11
ok good so it shouldnt be to complicated... and about raising boost? how do u install a g-valve? are tehre sites or anything on how to do it?
Old 06-02-2004, 11:38 PM   #12
Go to http://www.thedodgegarage.com/ and on the left side of the page will be links. Click on Turbo Database and you will find what your looking for. I would highly suggest reading everything in the Turbo Database before you start doing anything to your car for your own good.
Old 06-03-2004, 12:03 AM   #13
alrite awesome thanx alot
Old 06-03-2004, 12:07 AM   #14
Glad I could help.
Old 06-03-2004, 12:11 AM   #15
it says that it controls from a minumum of 22 psi?? can it work if i only want like 15 or something? and also im sure i already asked this but would i need bigger injectors or can i just play around with the air fuel ratio? and also would u suggest the eay one or the harder one with the bleed valve or just the grainger?
Credit Cards | Debt Consolidation | Free Advertising | MPAA | Credit Cards
Page generated in 1.38001 seconds with 13 queries
