2.2 vs the 2.5 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 31 Old 09-24-2013, 07:01 PM Thread Starter
My Ride: 1986 Dodge Daytona
2.2 vs the 2.5
I'm trying to get everything in line to start rebuilding my car, my goal is for 250-300 hp, I have a 2.2 turbo from an 86 Turbo Z and a 2.5 from a 91 Shelby Daytona, Which is a better starting point? pluses and minuses of each? the motor will go into my 86 Turbo Z
Jdm_Slacker is offline
post #2 of 31 Old 09-24-2013, 07:13 PM
Level 1 Supporter
83scamp's Avatar
My Ride: 83 Scamp GT
Re: 2.2 vs the 2.5
The 2.5 will definitely give you much better torque and drivability. Especially if your goal is less than 300 hp. That's an easy number to hit these days. Be warned, you will need to upgrade to a a555 or better tranny. the a525 in your Z won't handle that kind of output from a 2.5
83scamp is offline
post #3 of 31 Old 09-24-2013, 07:22 PM
- OFFICIAL GEARHEAD -
ILIKESHELBYS's Avatar
My Ride: CSX/CS/GLHS
Re: 2.2 vs the 2.5
You'll need to consider doing a full T2 upgrade from the T1 log motor as well to hit the golden 300HP mark. And the A555 is a must have at that power level for sure. Been there done that. You will also need a custom cal w/either engine.
The 2.2 or 2.5 will serve you equally well, a 2.5 has better low end torque for a heavier car like the G body Daytona, but a 2.2 is a better rev'r so if RPM is your drug of choice go with the 2.2. Your car came w/a 2.2 from the factory, it's a prooven combo when combined with the proper final drive tranny.
This article deals with converting pre-1988 Chrysler turbo 1 cars to turbo 2 status. This article also specifically deals with converting a 1985 turbo 1 L-body (ie Shelby Charger, GLHT) but will apply to other bodies and years and known differences will be noted. Also I assume no resposiblity as to the validity of this information, and assume no responsibility for any damage or harm that may come to you by using this information. And as always when working on an automobile certain safety procedures must be followed. This article is written as my experince with converting my 1985 Shebly Charger with the knowledge mostly gained from those generous souls on the SDML (Shelby Dodge Mailing List - Shelby Dodge Mailing List (SDML)).
The most popular reason for doing this conversion is the addition of an intercooler. An intercooler could be added to a 1988 and later turbo 1 quite easily becuase of the revision of the intake design lends itself much better to intercooler tubing. If you notice the outlet of your early turbo 1, the turbo and the inlet of the intake they are pointing directly at each other with no room to run tubing in between. It is possible to cut off the inlet to the intake and re-weld it pointing forward in order to add the intercooler tubing but the later style intake used in the turbo 2 conversion flows much better and more evenly between ports. The reason people like to add intercoolers to their turbo cars is that it allows higher levels of boost pressure to be safely run in the engine and thus more power put out because the more air molecules in the combustion chamber (ie higher pressure and more dense from cooling) the more expansion occurs. The intercoooler allows this because the boost pressure safely run is limited by detonation within the engine or high combustion temperatures, both of which will ultimately ruin pistons as well as other internal components. The intercooler prevents this by cooling the compressed air coming out of the turbo before it goes into the head of the engine.
While it may seem that one could just add the new intake and run tubing to the intercooler, you will find several small porblems that add up to warrant doing the complete conversion.
Problems:
1. The new intake is from a blow-through type system where the throttle body is after the turbo instead of before like you may have now (suck-through system).
2. The new intake with its longer runners, hits the early turbo one exhaust manifold (solved later in article).
3. Since the old intake did not flow evenly amoung cylinders some injectors are fired richer than others by the computer to compensate.
4. The electronics changed in 1986 to use a new distributor ( this only applies to 1984 or 1985 turbo cars).
5. The wiring is slightly different between the new intake setup and the older one.
Solutions:
1. Along with new intake you need the new style throttle body
2. Get the later style exhaust manifold, or use your own and grind down the section where the intake and exhaust hit. Note this is the only difference between the early TI and the later TI/TII manifolds is the later is notched appropriately).
3. Use a TII computer
4. If you have a 1985 distributor, get the new shorter, wider, 1986 distibutor and internal elctronics (hall-effect pick up).
5. Get the new end connectors for the TPS (throttle position sensor) and AIS (automatic idle speed) motor
Parts:
Intake: 1988 or later turbo intake off any model Chrysler car
This can be a one piece or two piece intake (off Shelby TII or Daytona TII cars). The two piece intake is much rarer so I would advise using the one piece, while tuned for slightly more low end, is much more abundant.
Injectors: stock TII injectors or mopar performance 804 injectors
While you could use your stock injectors keep in mind that the computer you will be using is calibratred for the TII injectors that flow more and thus you would have to keep an eye on your air to fuel ratio (oxygen sensor guage) to make sure that you don't run lean at higher boost. 804's may run richer than the sotck injectors allowing more boost but that is up in the air some respected individuals have said that Chrysler changed the flow of the injector and is now the same as stock TII injectors.
Fuel Rail: You need the fuel rail and pressure regulator that goes with the intake you got
Distributor: If you have a 1985 car get a 1986 turbo distributor
The turbo elctronics changed in 1986 so if you are intercooling a 1985 turbo I get a 1986 turbo distributor and the internal pick up. L-body turbo 2 cars, 1986 and 1987, both use 1986 electronics. If you have something like a Daytona I belive that the electronics may have been changed in the distributor again in 1987 so I would suggest a 1987 distributor.
Throttle Body: 1988 and on turbo blow through intake or 3.0 - 3.3 V6 multi-point injection throttle body
You can use any blow through throttle body. They are of 46mm diameter. You will also need the AIS and if possible the TPS that goes with the throttle body. The earlier TPS is the same electronically but if you wish to use the later wiring connector the new TPS is needed. The new AIS is a four wire system instead of two and the wiring will be addressed later. You can also use the throttle body off a multipoint injection Chrysler 3.0 or 3.3 V6 which is of 52mm diamater. The TB can be found more easily on early 3.0's (1989?) and all 3.3's I think. This is the TB used in the Super 60 system. It will yeild more power at high rpm and high boost levels but may reduce your fuel efficiency because of lower port velocity. The intake throat must be opened up a bit to accomodate the larger TB butterfly. This will be addressed more later.
Exhaust: 1988 and on Turbo I/II exhuast manifold, or grind your existing one.
If possible pick up the later style exhaust manifold, this will make your job easier. If you can't find the later style or don't want to spend the money on it, it is possible to modify your existing manifold. The only real difference between the two is that the later has a notch in it to clear the new style intake. You can simply use a bench grinder to notch your exisitng one. More discussion will follow on this later.
Computer: Turbo II computer
Dependent on what body car you are converting your computer options may change. For L-bodies you can use the 86-87 GLHS computer with the least effort. It only requires that you add two wires to the red wiring harness connected to the computer. I will address this specifically later but it is for the new two wires on the four wires AIS. These computers may be hard to come by so I would suggest picking up a GLHS Stage II computer from Mopar, they only run $130 from the place I got it. The other choice is to run the CSX Stage II or stock type computer ( I believe the Daytona may use this computer too). This requires the addidtion of the two wires as above and moving two wires to different cavities on the connector. The advantage of this computer is that it has more on RAM and I believe that it makes faster calculations as well. For other body styles, I believe that the Daytona or CSX Turbo II computer should be used or use the CSX Stage II computer.
Intercooler: Stock Turbo II/III/IV intercooler, aftermarket incooler, or Ford, Isuzu, Dodge Conquest, ect....
If you want to go for that stock look, pick up a stock turbo II/III/IV intercooler and radiator. These may be installed into a turbo I with only minor modifactions to mount the radiator. Or just pick up any stock mopar turbo II/III/IV intercooler, a Spearco or other aftermarket intercooler, or other make like a Conquest or Volvo intercooler and mount it up front in the fascia where it will get the most air flow across it like I am doing. Warning some intercoolers may be better than others. Mopar intercoolers are a good choice but the Conquest intercooler is better if you put bigger hose barbs on the end tanks. If you do mount it up front you will have to make your own tubing. But this is not difficult given 2.25 inch exhaust pipe and radiator hose to make it custom to where ever you decide to mount it. Remember the more air that goes through it, the cooler the air inside gets, and the more power you'll produce.
Wiring Connector: 1988 and on Turbo I/II throttle body connection and O2 wiring connector or get GM wiring connectors at NAPA, Car Quest, or other parts outlets
By far the easiest way to add the wiring connectors for the Turbo II blow though throttle and three wire O2 sensor is to pick up these off a salvage yard car. The Turbo II has a three wire O2 sensor. The new two wires just go to ground and ignition 12 volts. While it is not essential to have the three wire oxygen sensor, it would be beneficial to use it since it has an internal heater and will reach operating temperature quicker giving more consistant readings, better emissions, and better cold fuel efficiency. If you cannot find a salvage car to pull these connectors off, you can buy the assembled harnesses from Turbo Electrics.
Turbo: Turbo II turbo or modify existing turbo
The inlet and outlet of early turbo 1 turbo's points straight up, this does not lend well to intercooling since you will have to make sharp turns to point the tubing towards the front of the car. However the compressor housing may be turned forward, so there is no need to get another turbo. Note on turbochargers: The Garret turbo are larger and will flow more air at high boost while the smaller Mitsubishi turbo has less turbo lag and will spoll quicker. Choose turbo's by your planned top boost pressure.
Airfilter: Turbo II or late Turbo I airbox or Cone style universal filter
If you are going for a stock look, pick up a Turbo II or late Turbo I airbox and tubing. If you want maximum performance then I would go with a open element high flow filter perferably ducted with cool air. This is what I will be doing.
Miscellaneous:
Blow-Off Valve: You can get away without picking up a BOV, but if you want the most life out of your turbo then I would suggest getting one. Stock Chrysler BOV's will hold without leaking until about 15 psi and only cost $15 from the dealer. Early Eclipse and Talon BOV's (90-95) will hold until about 20 psi I believe. They use a metal diaphram so they won't swell and burst under high boost.
ILIKESHELBYS is offline
post #4 of 31 Old 09-24-2013, 07:32 PM Thread Starter
Re: 2.2 vs the 2.5
would the trans from the 91 bolt to the 2.2? and if i used the 2.2 could i not just use the parts off the 2.5 to convert it to T2?
post #5 of 31 Old 09-24-2013, 07:36 PM
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
Re: 2.2 vs the 2.5
Go weigh the car. My rule is 2800+ 2.5, 2800 or less 2.2. A friend put a 2.5 in his 85 Laser that was just over 2600lbs. It would roast the 225/50 15 Dunlop SP8000's all day long unless you launched it from 1100rpms at the track. Was funny to watch it go up against V8 drag cars. V8's all loaded up on the convertor waiting to go and he's just barely off idle. They'd get a slightly better 60ft and he'd real them in on the top end. My 87 ShelbyZ at 3120lbs LOVE'S the 2.5 though. Trying to get it rolling with the 2.2 was like trying to leave the pits at LeMans in the rain. Lot's of revs and clutch slippage. The 2.5 is a blip and let the clutch out and go.
GLHNSLHT2 is offline
post #6 of 31 Old 09-24-2013, 07:51 PM Thread Starter
Re: 2.2 vs the 2.5
post #7 of 31 Old 09-24-2013, 08:03 PM
My Ride: 1985 Dodge Omni GLH
Engine: 2.5 swap
Re: 2.2 vs the 2.5
i run a 2.5 in my GLH and i love it.
stargazer7467 is offline
post #8 of 31 Old 09-24-2013, 08:38 PM Thread Starter
Re: 2.2 vs the 2.5
still no answer to my question lol
post #9 of 31 Old 09-24-2013, 08:43 PM
AKA: knownenemy
signsoflife22's Avatar
My Ride: 1987 GLHS #0896
Engine: 2.2 8 valve
Re: 2.2 vs the 2.5
Noone seems to want to answer this question you've asked twice....
YES; The trans will bolt to the 2.2(there are some other mods required though)
See this thread:
A525 to A555 Conversions L body
And you can use the rod linkage from the a525.
See this thread:
A555 Rod Shifted L-Body Conversion
As far as bolting the T2 set-up from your 2.5 to the 2.2; YES, you can do that as well.
However, you'll need the electronics and wiring at least.
Surely there are other members with much more experience with such a swap.
Give this thread a little while and, I'm sure that everything you want to know will make its way into it.
best wishes to you my friend.
GLHS#0896
Under Construction
View the project log----------->1987 GLHS#0896 Project log<----------View the project log
signsoflife22 is offline
post #10 of 31 Old 09-24-2013, 08:49 PM Thread Starter
Re: 2.2 vs the 2.5
Thanks for all the info!! really helps!
post #11 of 31 Old 09-24-2013, 10:30 PM
TryHard Status
turismolover22's Avatar
My Ride: 1986 Daytona Turbo Z
Re: 2.2 vs the 2.5
If you go 2.2, in the z, take the top end and rods from the 2.5 and swap them into the 2.2 block. Buy forged pistons. The 86 is already wired for a charge air temp sensor, just swap the injector harness. Then just rewire a pkug in for the tps sensor, and add two wires for the air idle speed motor. Drill and tap the intake for the air charge sensor as well. Do a little rewiring at your logic module connectors in the car, and get an 87 t2 calibration.
You could run the 2.5 long block in it as well. If you were to use the 91 wiring, it would require a complete body and engine harness swap, or a long weekend cutting and splicing what you can use on the 86 to the 91 engine and dash harness.
The choice is yours.
turismolover22 is offline
post #12 of 31 Old 09-25-2013, 06:59 AM
AKA: knownenemy
Engine: 2.2 8 valve
Re: 2.2 vs the 2.5
See, told ya someone would chime in.
Thanks turismolover!!!
post #13 of 31 Old 09-25-2013, 07:36 PM
Level 1 Supporter
My Ride: 86 daytona t-tops
Engine: 2.2 T1 conv. to T2
Re: 2.2 vs the 2.5
Should have cable linkage for the 525 trans. that's what mine has and its an 86.
What kind of intake manifold do you have. You should have 88 or newer one piece or a 2 piece for doing a T2 conversion.
tthcare is offline
post #14 of 31 Old 09-26-2013, 08:19 PM Thread Starter
Re: 2.2 vs the 2.5
I have all the parts off of the 2.5 to do the conversion, only thing about using the 2.5 that turns me away is redoing all the electrical and i need to get all the vacuum lines for it, is it worth the time? plus since i am rebuilding motor either way i could just bore the 2.2 to 2.5
post #15 of 31 Old 09-26-2013, 09:41 PM
Legendary Driver
GLHNSLHT2's Avatar
Re: 2.2 vs the 2.5
Vacuum lines are pretty much the same thing. Electrical is just converting the wiring over to 87 T2 specs (which you'll have to do either way) and getting a custom calibration for it. You'll want to upgrade the trans too. The 525 won't take much and a solid bobble strut breaks the case in one good launch (been there done that) I recommend a 1990 523 trans. Bolts in and has the nice 3 plane shifter setup which makes shifting a dream. Also has a 3.50 gearset which gives you close ratio 1-4 gears and a taller 5th for highway cruising.
Human Verification
