07-11-2004, 05:54 PM
My Ride: 1987 LeBaron
Engine: 2.2L Turbo II
Originally Posted by Chris W
Some side to side play is acceptable as long as blades do not contact compressor housing. In and out play is not acceptable. The best way to avoid in and out play is to use a performance blow off valve. Your turbo should be rebuilt soon before too much damage occurs which will only cost you more money to repair.
As i suspected, and i had been using a BOV for quite some time, for as long as ive had the car intercooled and running 10+psi of boost. it is simply a talon unit though and perhaps is not suited for the 19 PSI that i had been using last year.
I have already perused TU fairly extensively and was seriously considering getting a rebuild done by your shop, but am worried about the additional down time this may cause. I am not sure as to how much work you have done for customers north of the border, but do you have any estimates as to a rebuild job on a turbo such as this? While its in i would probably be interested in getting some small upgrades as well, ie: exhaust wheel clipping, larger swingvalve etc.
there is one other concern i noticed and that was that there seems to be a crack in the exhaust turbine housing near the exhaust bypass port. hard to tell its size without taking the SV off, but is this a serious problem?
Thanks for your time. Please let me know what you can as soon as possible.
Joe McDonald
