Old 07-19-2004, 10:55 PM   #1
Waste Gate Actuator
My Ride: 1986 Dodge 600 vert
Engine: 2.2L Turbo I
I need to know what I have to look for when buying a wastegate actuator for my stock 86' 600. I don't need one thats going to increase boost because that would shut the engine down. My stock actuator arm broke at the end and now it is scrap unless I welded a washer or something to it to hook up to the wastegate. Also how do you adjust it so that it does not create to much boost or is that handled by the computer.
Thanks
dodge600 is offline
Old 07-20-2004, 01:00 AM   #2
My Ride: '89 Daytona Shelby
I'd cut the remaining rod and thread the end of it to match an "eye" bolt from your local hardware store. Join them with a threaded coupler and lock nut. Can't help you with the tension but measuring another cans arm should get you close enough.
puppet is offline
Old 07-20-2004, 10:44 AM   #3
My Ride: 1986 GLHS #126
Engine: stock
i'd recommend a new larger capacity wastegate actuator (or "can"), you can buy from FWD Peformance or Turbos Unleashed, along with a special bracket to accept the new can, for under $100, good thing is the unit comes with an adjustable arm already so you can fine tune it, and if you ever upgrade your setup's swing valve you'll have a can capable of handling that as well, heres a pix (can is the zinc chromated yellow looking thing on the left, I got this one from TU):
Marcus86GLHS is offline
Old 07-21-2004, 11:27 PM   #4
My Ride: 91 Shadow ES
Engine: 2.5L
i have a TI adjustable ( near new can ) for sale and im in ontario..
Radiant_Red is offline
Old 07-22-2004, 11:02 AM   #5
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
The new TU unit is nice. The adjuster is easy to get to when the motor is installed, as it is right next to the can.
minimopar is offline
Old 07-22-2004, 11:04 AM   #6
id just go wrecking yard hunting for one off a blow tru car, which I am assuming yours is. just bolt it uo to your stock turbo
TurboShadowES is offline
Old 07-22-2004, 11:07 AM   #7
My Ride: turbochrysler.com
I won't argue that the TU actuator is a nice piece, but for someone looking for a stock replacement on an 86 TI It's overkill in my opinion. Best bet is to find a good used actuator and swap them. I've got a bunch if Frank (Radiant Red) can't help you out for some reason.
Turbodave is offline
Old 07-22-2004, 08:57 PM   #8
My Ride: 88 Shadow
Feedback: (7)
He needs a T1 can, not a T2 can. They are vastly different. And if he is stock an 86' would have a suck-through style.
I have an 87' T1 can for sale(they are the same as 86'), check out my thread in the for sale section. $20 USD shipped to the U.S., but to ship to canada is more expensive so I'll say 25.
The ECU controls the boost, don't worry about it.
moparzrule is offline
Old 07-22-2004, 09:15 PM   #9
My Ride: 88 Shadow
Feedback: (7)
Chris I need to talk to you, I sent an email with no response, I will PM you now.
Advertising | Credit Cards | Debt Consolidation | Free Ringtones | Personal Finance
Page generated in 0.35189 seconds with 13 queries
