01-27-2005, 11:40 AM
#32
Answer?
My Ride: Daytona base
Engine: 2.5 Turbo
Originally Posted by DocFish
Thanks Dean. I haven't tried to mock everything up yet, and now you've saved me the trouble. Think I'll whack the outlet off and weld an elbow on. I don't know of anyone that could machine the Chrysler housing around here. I'm also waiting for a .63 turbine housing. But, would remachining the .42 compressor housing be better than using the .60 housing?
Can anybody answer this question?
steve
01-27-2005, 11:54 AM
#33
From looking at my .48 and .63 housings, its not a matter of machining. The .63 hsg is so much bigger than the .48 hsg so theres nothing to machine.
01-27-2005, 12:01 PM
#34
Engine: 2.5 Turbo
I mean, On the compressor side. Which would be better? The .60 a/r or the stock .42 a/r machined out for the 60 trim wheel?
01-27-2005, 12:19 PM
#35
I don't think that would make any difference as the housing is still really small. If your going for lag issues and no top end, do the .48 machining but for more top end, do the .60.
02-13-2005, 08:37 AM
#36
ford turbo in a t2 housing
My Ride: 1989
Engine: 2.2 t2
I have made this turbo using a .60 ford compressor side and center section installed in to a .48 t2 dodge turbine housing, fits pretty good you'll need to make a adaptor for the turbo on the compressor outlet hopefully that wouldn't be problem with flow.I'm going make a mistu turbo waste can work with this turbo. well try hopefully this help people I posted pictures
Sean
87 shadow turbo t2 2.2 intercoolered
02-13-2005, 02:46 PM
#38
My Ride: '87 Omni
Engine: Dodge 2.2
Hmmmmmm, you've got the gears grinding for me too, a friend of mine has like 5 of those turbos laying around....
02-15-2005, 12:32 PM
#39
My Ride: 1989
Engine: 2.2 t2
here is some more pictures of the turbo just test fit it in there
I used the waste gate can from T1 turbo and all the lines too...
02-15-2005, 03:09 PM
#41
My Ride: 1999 Jeep Wrangler
Engine: AMC 2.5L
Here is a pic of the one I'm currently running on the Jeep. This one is off of an 85' XR4Ti. It works great!
02-15-2005, 03:14 PM
#42
Engine: AMC 2.5L
Originally Posted by Fastem
My question is, where can I find a .63 housing somewhat cheap?
Ebay!
02-15-2005, 05:00 PM
#43
Nice work Joel, I like the box for the dp, I think thats what it is?
02-15-2005, 07:53 PM
#44
My Ride: '87 Omni
Engine: Dodge 2.2
The box looks like its on the inlet of the turbo, I think it was for the carburated applications, unless its custom. A friend of mine has a 2.3 turbo carb setup that has something similar.
02-16-2005, 09:12 AM
#45
Engine: AMC 2.5L
Thanks,
The "box" is actually nothing more than a way to plumb my exhaust pipe up to the turbo. Since I turbocharged a n/a 2.5 motor, the exhaust manifold had no provisions for mounting the turbo to it, plus there really wasn't any room on that side of the engine compartment either. So I had a custom pipe bent up that runs from my exhaust manifold, down under the oil pan, and back up the other side of the motor and into the "box". The "turbo unit" mounts on the bracket that would normally hold my a/c compressor. That positioned the turbo high enough in the engine compartment to allow a nice gravity feed for the oil return line back to the pan. I was concerned that with the turbo that distance from the exhaust manifold, there may be some "lag" in getting it spooled up, but it works great. Throttle responce to boost is almost linear.  (Below are a couple of pics of the bracket I mounted the turbo on... before and after mounting)
I checked Ebay last night, and for anyone wanting to upgrade to one of these Garrett turbos (.60 A/R - .48) from your Mitsu, there are several out there for sale. They're going for anywhere between $10 - $150!
