11-19-2004, 10:13 PM
My Ride: 99 Cummins
Engine: 5.9
Originally Posted by Putter
A local race shop (usually the oval track shops have it in stock) can get you some areoquip line that should be the proper dia (5/16ths i think), that should hold, i'd hate to see a turbo get fried cause of cheap rubber.
I would not suggest using the aeroquip hose unless its pure silicone. I was given some aeroquip that is partially silicone (looks like its wrapped in blue tape) and it restricts with heat.
Do replace the turbo oil line, its only $40 from the vendors. Also, get some silicone hose, if you can find it locally, cool, if not, TU has a section for $7 (i thought high at first but then i realized i wasted more than that in gas looking for pure silicone hose and i still havent found any.. thats the funniest)
