11-15-2004, 05:56 PM
My Ride: turbochrysler.com
Originally Posted by shawny2087
check the vac line to the boost gauge. also to check to see if the turbo moves freely take the airbox out and plumbing also then put your fingers in the intake side of the turbo and try to turn the compressor wheel.also check for shaft play (updown,left,right) there should be a little play( for bearing clearences) almost none
The 85 Turbo has a larger EGR housing on the compressor inlet that makes it difficult to chekc for shaft play.
The first thing I would look at is the wastegate actuator rod, it's not unusual for the clip that holds it on to rust and let the arm pop off. The wastegate is what controls the exhaust flow through the turbo and the boost output. Look at the backside of the engine and towards the right will be a round metal can with a rod about 6" long sticking out of it. The can wll also have a vacuum line connected to it. Follow the rod and it should fit over a post on a little arm that sticks up out of the back of the turbo. If the arm is off, reinstall it and see if your problem is solved.
