01-22-2005, 02:43 PM
#22
My Ride: 1985 Laser XT
Engine: 2.2l
I don't know if this will help but I have removed 2 cat. converts from 2 seperate vehicles because of lack of power and excessive heat buildup. the 1st converter would glow in the dark, the 2nd under normal running was fine until you stood on it, then the broken ceramics would get pushed into the exhaust end of the convert. this was found out upon removal of the converter, with an flash light shining in the exhaust end you could see the broken pieces and how they had been fitting into the end of the converter.
