Old 01-13-2005, 12:39 AM   #1
Mitsu vs. Garrett Turbos
My Ride: 85 Shelby Charger
Engine: 2.2L Turbo II (GLHS)
Ok, here is my question. I have a Mitsu turbo off of some car, not sure what. Anyway, are the exhaust manifolds the same? I am pretty sure the swingvalves are different, but didnt know about the manifolds. It looks smaller, but I dont have one from a Garrett to compare with.
fish2222 is offline
Old 01-13-2005, 12:47 AM   #2
My Ride: 2004 SRT4
Engine: 2.4
Feedback: (-1)
The swing valves are different. The manifolds are the same though. In fact, the only difference in manifolds that I am aware of are the VNT models have a higher nickle content than the reqular models. They all have a high nickle content, even our blocks.
Andre Parker is offline
Old 01-13-2005, 11:36 AM   #3
You can swap them between manifolds. What are you putting the mitsu on? hopefully not a TD that you want to liven up.....
The Barron is offline
Old 01-13-2005, 01:11 PM   #4
No, im not gonna liven anything up with it. I just am wanting to use the exhaust manifold for a T1 to T2 conversion, but wasnt sure if they were the same. Just wanted to check before I tore it all apart and then had to go find one to clear the new intake runners.
fish2222 is offline
Old 01-13-2005, 01:32 PM   #5
My Ride: 1987 Shelby Z
1/4: 11.620
The '88 and up T1 manifold (used with the mitsu) will work for you. The '87 and older T1 manifolds (old style Garret T3) are different, the notch in th etop for intake runner clearance is not there cause the early 'log' T1 manifold did not need that clearance.
B.A.P. is offline
Old 01-13-2005, 05:05 PM   #6
Got a Grinder?
Old 01-13-2005, 11:28 PM   #7
My Ride: 1990 Spirit
Engine: 2.5 T1
So... you can hook up a older 87' and older turbo to a newer style manifold? Or does the notch affect it somehow?
90Acclaim is offline
Old 01-14-2005, 12:28 AM   #8
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Yes, I've got an '85 turbocharger on my Daytona.. Works like a champ, www.thedodgegarage.com has a great article on how to adapt the early turbo to use on a later intake or engine. I followed their precedure more or less.
Una is offline
Old 01-14-2005, 08:15 PM   #9
1/4: 11.620
Originally Posted by The Barron
Got a Grinder?
Been there, done that....
B.A.P. is offline
Old 01-14-2005, 08:23 PM   #10
My Ride: '87 Omni
Engine: Dodge 2.2
Bench grinder made less than a 5 minute task of grinding my turbo to clear.
Putter is offline
Old 01-14-2005, 09:28 PM   #11
My Ride: 88 Shadow
Feedback: (7)
Yup, happy grinding
Ahem, been there done that too
moparzrule is offline
Old 01-14-2005, 09:53 PM   #12
My Ride: '87 Omni
Engine: Dodge 2.2
The only bit I didn't enjoy was plugging all the holes and then having to clean all the metal out before pulling my rags, seems dangerous Metal is hard on engines....same thing went for drilling and tapping my compressor housing outlet for a hosebarb.
Putter is offline
Old 01-15-2005, 03:23 AM   #13
well.. you'd take the housing off for that wouldnt you? A little shot of compressed air and should be good.
Old 01-15-2005, 12:39 PM   #14
Una
Engine: 2.5L Turbo
I didn't take anything apart when I ground on mine.. hehe, actually poured metal dust out of the turbine housing when I got done. ;>
Una is offline
Old 01-15-2005, 11:58 PM   #15
Does anyone sell an adapter to make this work easier?
fish2222 is offline
Personal Finance | Buy PSP | Credit Counseling | Problem Mortgage | Car Credit
Page generated in 0.42530 seconds with 13 queries
