01-13-2005, 11:38 AM
t4, make it fit?
My Ride: Daytona base
Engine: 2.5 Turbo
What do you have to do to make a t-4 comp housing on a stock manifold and stock head? See, going with a T3/t4 hybrid is alot cheaper than going with a super 60 or 70. Help?
Steve.
01-13-2005, 12:15 PM
My Ride: 88 Shelby Z
Engine: 2.2 T2
I welded a couple of elbows on the compressor output to clear the head.
01-13-2005, 03:47 PM
Engine: 2.5 Turbo
Is that all you have to do?? I need to know exactly what I need to do to make it fit.
Steve.
01-13-2005, 04:18 PM
I used a 2 rubber elbows from a RX7 Turbo II car, perfect bend and fit. As for direct bolt on, I had to modify my coolant line, I had one for a stock garrett but wouldn't clear the huge compressor so I made some elbows etc from pipe at Home Depot and then hooked up to the braided line.
01-13-2005, 04:43 PM
My Ride: 1991 Daytona Shelby
Engine: SOHC 2.5L
Yes that too as I remember, you need an 90 degree elbow at the turbo itself for the Braided line to clear.
01-13-2005, 09:10 PM
Engine: 2.5 Turbo
what if I used the to4e comp housing?
Steve.
01-13-2005, 09:46 PM
Steve.
Thats what I am talking about,
01-13-2005, 09:49 PM
Engine: 2.2 T2
Ditto. The B series may fit better, but I preferred the flow characteristics of the E series.
01-14-2005, 12:19 PM
#12
Engine: SOHC 2.5L
Originally Posted by 89daytonaTII
would be neat to hear any facts/theory on what an E wheel in a B housing changes as far as the E wheels characteristics
I'll get more info from my shop www.monster-turbo.com , I was at the time deciding if I should go with a T03 or T04E cover, my shop suggested the T04B as I would have a T4 family housing matching to a T4 wheel, but would get much much better efficiency rather than the T03 especially top end but would not sacrifice much lag at all, compared to the T04E housing, its a compromise on both ends, for my street car its perfect.
They had a customer of theirs make 450WHP+ with this compressor setup. . .on a different application however, some DOHC 16V import
01-14-2005, 04:38 PM
#13
yeah your the only one that I've heard of with that setup, it picks at my curiosity.
