01-14-2005, 03:25 PM
Will you post what you did and how you acomplished it so people might be able to do something similar?
After everything is done and working right, I'll definitely do a complete write up.
The clearances are tight, but everything fits under the hood with no problems. I'm sure the Mitsu SOHC manifold should fit fine too. To run the engine, I'm going to use an older version of a Haltech standalone.
I'm planning on 400whp, so the single TDO5-16g that I had on the old engine wouldn't be enough. Instead I'm using two TDO5-14b's. This is probably a little bit overkill, but I don't think the turbo lag will be too bad considering the decent low end torque and 10:1 compression ratio.
