Old 01-14-2005, 07:27 PM   #1
Taking off turbo
Can someone please help me, im taking the turbo off my car and i need to know what i need to remove first to get at the turbo, i.e intake manifolsd.. THe car is a 89 shelby turbo II, and i was also wondering if that year came with a stock bov, there is something attached to the airbox but i cant make out if it is a bov..
89Shelbyturbo is offline
Old 01-14-2005, 09:34 PM   #2
Lt.Lee
just 3 words pull the head. unhook exhaust and pull the manifolds, turbo and head. Trust me alot easier.
Old 01-16-2005, 02:39 AM   #3
My Ride: 99 Cummins
Engine: 5.9
Images: 6
take off oil and coolant lines.. turbo intake/out hoses.. pop off exhaust.. 15mm stubby wrench and regular 15mm wrench and turbo is out in about an hour..
if still has the turbo support bracket, youll need ratchet/15mm socket.
Itll help to pull passenger side axle (adds about 30 mins total)..
I replaced my turbo the first time and didnt pull the axle, instead i brought it up over the top of the transmission.. wasnt too hard to do- this was before i knew anything about these cars... id defeintly take the axle out and take turbo out the bottom next time.
Also, it may be helpful to take off front moto mount, and swing engine backwards, so that the turbo is more open from the bottom.
It could be easier to pull the head, but then you have to disconnect even more items, replace gaskets and new headbolts so youre already $40 down. May be worth the headache though. Especially if the headgasket may be gettin a bit old.
Timmay2 is offline
Old 01-16-2005, 03:17 AM   #4
My Ride: '88 Sundance
Engine: '89 2.5 TI
You must be superman to break any of the mounting nuts loose with a stubby wrench.
I pulled the mitsu off of my spare manifold awhile back and had to double wrench it and stand on the manifold!
Tony
tonyz2897 is offline
Old 01-16-2005, 09:26 AM   #5
Lt.Lee
you do not have to replace the head bols. gary donovan syas just as long as you hit 100 ftlbs on th elast 1/4 turn you are fine on th ehead bolts..
Old 01-17-2005, 02:39 AM   #6
My Ride: 99 Cummins
Engine: 5.9
Images: 6
Tony
put the stubby wrench on nut, , and then use something to hit it.. i.e 3/8" extentions and a hammer.
Timmay2 is offline
Old 01-17-2005, 03:02 PM   #7
My Ride: 85 laser
Feedback: (7)
that does have a blow off valve its in the air box , the way these are set up you cant get the intake manifold off because the exhaust manifold blocks access to the bolts pulling the head is much easier because youll probly open a can of worms somwhere along the line a bolt will break or a line and having the head off will make this much easier to deal with
jim
jim34 is offline
Ringtones | Share Prices | Loans | Personal Finance | Song Lyrics
Page generated in 0.37101 seconds with 13 queries
