Old 01-23-2005, 11:08 PM   #1
Boosting fuel questions??
bigdaddy1010
I'm gonna be running my Turbo II conversion and I have to upgrade the fuel. It was a 1986 Chrysler Lebaron 2.2 Turbo I, with a modded intake manifold off a 1989 dodge caravan with intercooler. Will be running 15-16lbs of boost,
1. so what injectors should i being going for???
2. And will a inline 255 walbro fuel pump work fine, if i just unhook the stock intank pump??
3. And what kind of ECU should i run, the stock Turbo II of of another car or a performance Stage three from FWDperformance or else where???
Old 01-26-2005, 08:06 AM   #2
My Ride: 89 Spirit ES
Engine: 2.5 STD TII 20psi
+20% injectors will be fine for 16psi. 255 l/hr fuel pump is more than enough and is very efficient. For the ECU...I'd go with Turbo's Unleashed custom calibration with a 3 bar module built into the comp...also have them set the fuel for you as well so you don't have to toy with it.
www.******************** They also have your parts for fuel.
-Bryan
89 Spirit
Dave is offline
Credit Counseling | Loans | Myspace Proxy | Notebooks, Handhelds & PDAs | Loans
Page generated in 0.27335 seconds with 13 queries
