Old 01-29-2005, 02:33 AM   #1
boost leak?
My Ride: 1987 CSX
Images: 4
it's almost three degree's outside ! so before I go diggin around in my car can somone maybe throw me some idea's...
I have no blow off valve yet when I shift it sounds like I do car is a 87 csx with a 2.5 exhaust and high flow cat and k&n panel filter....when it boosts it doesn't go above 7 psi...in 3rd gear on the highway at 4500ish it SLOWLY creeps up to 12 psi but will not hold.
the wasgate can and arm both work too btw any suggestions would be great )
thanks!
RSTURBO is offline
Old 01-29-2005, 09:51 AM   #2
Mopar_Nutz's Avatar
My Ride: Shelby Z's
Engine: 2.2 TII's
Have you checked all the connections in your IC plumbing? I had a clamp loosen on me a bit once and it caused a slight fluttering sound between shifts until it blew the hose right off.
Mopar_Nutz is offline
Old 02-01-2005, 11:06 PM   #3
My Ride: 1987 CSX
Images: 4
everything is tight.....and I pulled all the hose out to look for leaks but there wasn't any i'm going nuts!
RSTURBO is offline
Old 02-03-2005, 03:25 AM   #4
My Ride: 86 shelby charger
sometimes them air filter u install can sometimes sound like a bov throttle is shut and the air stops goin through for some reason, not sure why but my grandpas 86 sc did and his drove strong and fine
sup3rfr3ak is offline
Old 02-03-2005, 09:45 AM   #5
My Ride: 1987 CSX
Images: 4
shouldn't I have full boost by 3k though?
RSTURBO is offline
Mortgage | Loans | Mortgage Calculator | Credit Card | Free Credit Report
Page generated in 0.30515 seconds with 13 queries
