Old 02-02-2005, 06:24 PM   #1
boost problem
My Ride: 86 shelby charger
i bought a boost gauge and i suck into and blow into it works fine so i hooking it up to the vac line coming off the tb and just get vac no boost, then hook it up to the vac coming off the waste gate and just get vac no boost, try all the other lines i could get vac off but no boost, i tried all the 3 vac lines running right next to my vavle cover thats rapped up with 1 big line, didnt get no boost , just vac out of all of them i havnt tried cutting the big one thats runs with the other 3 lines because i dont kno what it goes to , but the turbo is spooling and working when u rev it up it spools away anyone have any ideas
sup3rfr3ak is offline
Old 02-02-2005, 07:56 PM   #2
anyone?
Old 02-03-2005, 04:39 AM   #3
My Ride: td
Hook it up to the intake manifod, any of the nipples or hoses comming off the intake manifold will show you boost and vacume. Also...just in case your checking for boost by reving, you most likely need to be driving the car to make any boost. Either that or your not getting any boost to the intake...ie major boost leak.
Geoff is offline
Old 02-03-2005, 11:29 AM   #4
Boost problem
tps25pentium
Try to connect the gauge as close to the manifold as possible. This way you will avoid restrictors, check valves, etc. Secondly, you will only see boost while you're DRIVING. If you still see no boost, then check to see if your turbo outlet hose is connected and sealed correctly. If still no boost then you have a problem. On the control side, maybe your boost solenoid is stuck shut or your wastegate is somehow open (but that would still show a few psi of boost).
Old 02-03-2005, 12:28 PM   #5
Feedback: (32)
You're not reving the car in netrual, are you?
You will never get any boost that. DRIVE HER.
tryingbe is offline
Old 02-03-2005, 01:40 PM   #6
My Ride: 1993 Dakota
Engine: 3.9
Thats the impression I got.
ACR Turtle is offline
Old 02-03-2005, 10:04 PM   #7
My Ride: 1978 Dodge stepside.
Engine: 318 Turbo Project
+1
I was gonna say something, but a couple people beat me to it.
Michael
MoparFreak is offline
Online Loans | eHarmony Coupon | Birthday Gifts | Charity | Free Ringtones
Page generated in 0.33030 seconds with 13 queries
