Old 02-09-2005, 09:50 PM   #1
Grainger Valve
My Ride: 89 Caravan
Engine: 2.5 Turbo
Hi, im new here and have just started fooling around with my turbo caravan. ive been reading on some sites about a grainger valve to control boost. ive tried some local industrial suppliers and they dont have a clue about what im talking about. is there a generic name for these valves, and what kind of supplier would carry them. i havent been able to locate a grainger outlet here in canada by using the search on their web site. as of now im using a small orifice at the wastegate solenoid to get the pressure up to about 10psi but id like a bit more and this valve arrangement looks like the cats meow.
amx1 is offline
Old 02-09-2005, 09:58 PM   #2
My Ride: Voyager
Engine: 2.5 .040 over cast
i believe they are called "pressure relief valves"
myplasticegg is offline
Old 02-10-2005, 02:53 AM   #3
My Ride: 89 Caravan
ANother van guy!!! Welcome. You can get them off of Ebay, but I reccomend posting in the parts wnted section... seems people on this site regularly have them, and if you were to buy on from the industrial supplier you have to do some modifications to it... whereas if you bought one from someone on this board it will be ready to rock!
FWIW I put a hole in my #1 piston when I ran 16 intercooled PSI in my van. Dont go more than 13-14 intercooled without fuel modifications..
Where ya located?
Jeff
My96z is offline
Old 02-10-2005, 02:56 AM   #4
My Ride: 04 Impreza
Engine: 2.5 SOHC
Images: 3
Go to a plumbing store and ask for a ball-check valve or an aquarium valve. They'll understand.
Moof is offline
Old 02-10-2005, 08:35 AM   #5
My Ride: 89 Caravan
Engine: 2.5 Turbo
thanks for the info. i was planning on running about 14psi, just below the computer cut off point. i was also thinking of running turbo II injectors just for a little more fuel as added insurance, what are yout thoughts on that? BTW im located in western canada, calgary alberta to be exact.
amx1 is offline
Old 02-10-2005, 11:53 AM   #6
My Ride: 1988 Daytona ShelbyZ
Engine: 2.2TII soon 2.5TII
I believe your injectors are the same as TII ones. Your van should be a 2.5 TI, they should be the same and your computer controls the pulse width of the injector adding the amount of fuel needed for the larger displacement. If you wanted more fuel for added security, you'd be better getting an adjustable fuel pressure regulator and maybe some +20 injectors, or adding an extra injector on a Hobbs switch which is probably cheaper.
dodge80_89 is offline
Old 02-10-2005, 01:43 PM   #7
Where from Alberta are you?
Check out this link: Edmonton Alberta T.D.ers
Next meet is on the 15th.
You can order the gringer valves from MCMaster Car. They come out to about $10 a peace then. See Gus Mahon's site RIP for good gringer info.
Laeter.
finallall is offline
Old 02-10-2005, 03:58 PM   #8
My Ride: 89 Caravan
Engine: 2.5 Turbo
im in calgary. ive tried gus mahon's site but it seems to no longer be around. i got my info on these from the dodge garage.
amx1 is offline
Old 02-10-2005, 04:52 PM   #9
My Ride: 1989 Shadow Es
Engine: 2.5L Intercooled
flybyuin2.2 used to sell them...not sure if he still does, but they're really good units, cheap, and he offered a money back guarantee.
CaptTurbo is offline
Old 02-10-2005, 05:20 PM   #10
Gusses site is still very much alive just like his spirit. Here ya go: http://www.gusmahon.org/html/boostcontrol.htm
Old 02-10-2005, 05:40 PM   #11
My Ride: 89 Caravan
Engine: 2.5 Turbo
thanks, from a calgarian to an edmontonian! whoda thunk it eh!
amx1 is offline
Old 02-11-2005, 12:15 AM   #12
My Ride: 86 shelby charger
anyone have a grainger vavle for sale or kno i could get a boost controler or something locally without ordering online
sup3rfr3ak is offline
Old 02-11-2005, 01:25 PM   #13
My Ride: 89 Caravan
Engine: 2.5 Turbo
ha ha this just gets better all the time. my fuel pump died this morning and had to get it towed to the shop (im an automotive tech). it turns out the tow truck driver runs a glh, ive seen it at the track. told me where to get a valve locally . thanks for all the info you guys supplied, im sure ill be needing more im kind of a turbo rookie .
amx1 is offline
Old 02-23-2005, 05:32 PM   #14
My Ride: 91 Eclipse GSX
Engine: 2.0
i believe i was charging $40 shipped to Canada within 5 business days so if anyone wants 1 just PM me, i also supply parts for them so no need to buy another controller if parts get lost while cleaning or ?
flybyuin2.2 is offline
Internet Advertising | cPanel Hosting | Credit Cards UK | Remortgages | Stag Weekends
Page generated in 0.44823 seconds with 13 queries
