Old 02-13-2005, 10:38 AM   #1
attn: turbo rebuilders, help
my question is simple, on the turbine side of the turbo is that "piston ring" looking ring the only thing that keeps oil from mixing in the exhaust flow? (provided no drain blockage) also how about compressor side seals?
spoonglh is offline
Old 02-13-2005, 11:41 AM   #2
yes, the piston ring is what prevents oil from going out the turbine side.
the compressor side should use a carbon seal, which is composed of many pieces, a spring, washers, spacers and a chunk of carbon.
xrattiracer is offline
Old 02-14-2005, 02:33 PM   #3
WishIhadaSig
Exactly, unless you have one of those oddball dynamically sealed compressors In that case, it'll have a piston ring type seal on the compressor side as well.
Clark
Wep cracker | Loans | Free Myspace Layouts | Internet Advertising | Remortgages
Page generated in 0.49942 seconds with 13 queries
