02-14-2005, 02:55 PM
installation of boost control
My Ride: 89 Caravan
Engine: 2.5 Turbo
got my "grainger" valve and other associated fittings to make it work. now for a couple of questions. first off, is it better to use the intake or the turbo output nipple as the boost source for the valve? im inclined to use the manifold, but i may be wrong. second, do you leave the stock quick release valve attached to the outlet nipple or just disconnect it altogether? im assuming that is what the valve in the stock air box is called. id would also assume if you use the manifold as the pressure source and disconnect the quick release, i would have to cap the turbo output nipple, correct? is there any danger of stacking up the boost pressure against the turbo with the quick release disconnected ( i'll be running about 14psi boost)?
