Old 02-15-2005, 02:44 PM   #1
Turbo Support brace
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
This may sound a little silly but How do you use the support brace on an aftermarket turbo.
I had a mitsu and the turbine housine has an extra hole for the brace to bolt up to and my new T3/T4 does not?
Also does the TU header move the turbo so that the brace needs to be modified?
I am asking because I thought it was almost necessary to have so the header doesn't crack
Thanks
Matt
speeduphoria is offline
Old 02-15-2005, 05:16 PM   #2
I know that there are people who dont run them, and claim that they dont have trouble. However I figure that it is on there for a reason, so might as well run it. The Turbonetics chrysler flange housings have the proper hole for the brace. Dont know about the TU header though.
OmniGuy123 is offline
Old 02-15-2005, 05:25 PM   #3
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
For the TU header...I think you are specifically NOT supposed to use any kind of brace. The SS used is very strong, but it expands at a much higher rate due to heat than the cast iron stock manifold. The brace can introduce stresses that can make things worse.
minimopar is offline
Old 02-15-2005, 05:32 PM   #4
Yeah, Chris at TU says not to use one. As for the stock manifold, I modded mine to fit my T3/T4 turbo, figured all that extra weight bouncing around can't be good for the manifold.
Old 02-15-2005, 06:06 PM   #5
Engine: 1987 2.2L
Oh yeah...I always use the brace on my stocker.
Old 02-15-2005, 07:12 PM   #6
Engine: 2.4 DOHC
Thanks guys I am going to get the TU header and forget the brace
I have one more question, what method would I use for the egt hole?(welded bung or threaded hole?)
Thanks
Old 02-15-2005, 08:20 PM   #7
I have a threaded hole on my stocker. I would probably just go clamp on style in the future though.
Old 02-15-2005, 08:44 PM   #8
My Ride: td
Thanks
I welded a bung into my tu header.
Geoff is offline
Old 02-16-2005, 06:51 AM   #9
My Ride: 1991 Daytona Shelby
Engine: 2.5L
I just asked the same question a few weeks back to Chris Faulk. You can read his response here.
http://www.turbododge.com/forums/sho...440#post586440
Frank
Frank is offline
Internet Advertising | Loans | Loans | Mortgage Calculator | Hookahs
Page generated in 0.37682 seconds with 13 queries
