Old 02-18-2005, 07:52 AM   #1
turbo line question
can i use garret t1 lines on a converted t2 ?? i was following the dodge garage and when i was ready to install the lines the wastegate can was in the way of the coolant line.
2fst4u is offline
Old 02-18-2005, 06:49 PM   #2
It can be done. If you can get two of the lines from the thermostat box to the turbo, you can cut them apart and put it back together with a section of good hose (silicone if available) using two of the same ends. I'm pretty sure I used two of the ends that go to the head.
supercrackerbox is offline
Loan | Mortgage Calculator | Ringtones | Loans | Stoves Range cookers
Page generated in 0.32937 seconds with 13 queries
